class with subclass
paulc
class with subclass
Post by paulc » Mon Dec 11, 2017 2:31 pm
I'm trying to create a simple baseclass with subclasses like in dht.py (ESP8266)
The problem is: 'myclass' has a different behaviour than the dht class, and I can't figure out what is causing it.
myclass.py:
class MyBase:
    def __init__(self):
        self.temp = 1
        self.printinfo(self)
    def measure(self):
        self.temp = 23
    def printinfo(self):
        print("This is info from MyBase")
class Hello1(MyBase):
    def printinfo1(self):
        print("This is info from Hello1 ")
    def getv(self):
        t = self.temp
        return t
class Hello2(MyBase):
        print("This is info from Hello2")
    def getv(self):
        t = "Hello2"
        return t
ok so I try:
import myclass
hello1 = myclass.Hello1
hello1.getv()
--> TypeError: function takes 1 positional arguments but 0 were given (This does not happen with dht, why?)
okay, then i try.
hello1.getv(hello1)
--> File "myclass.py", line 17, in getv
--> AttributeError: type object 'Hello1' has no attribute 'temp' (apparantly it dit not run __init__??, why?)
okay, so i need to manually run __init__.
hello1.__init__(hello1)
--> This is info from MyBase
hello1.getv(hello1)
--> 1 (ah!)
hello1.measure(hello1)
hello1.getv(hello1)
--> 23 (as expected)
So what is the essential difference between the dht class and 'myclass'?, or what am I doing wrong?
This has to be a simple beginners question :oops:
edit: code in codetags
Re: class with subclass
Post by deshipu » Tue Dec 12, 2017 6:45 pm
If you are calling a function on the class directly, it's just a normal function, you if it takes a "self" parameter, you have to provide it. The method magic where the current instance is assigned to the fist "self" parameter of the function only happens when you call it on the *instance* of a class.
> import myclass
> hello1 = myclass.Hello1()
> hello1.getv()
paulc
Post by paulc » Wed Dec 13, 2017 9:13 pm
Thank you very much for your reply.
I would never have gotten into trouble if my class would have had parameters.;-)
I guess I sort of understand the difference now. 'copy' or 'instance'
Post by deshipu » Wed Dec 13, 2017 11:35 pm
It's not even a copy, it points to the same class in memory.
paulc
Post by paulc » Mon Dec 18, 2017 7:54 pm
It actually is the same object indeed:
Hello1.measure(Hello1)
hello1.getv(hello1)
result: 23!
SpotlightKid
Post by SpotlightKid » Mon Dec 18, 2017 10:39 pm
I don't think you've understood the difference between a class and an instance of it yet.
Maybe you should work through a Python language tutorial on object-orientation?
