How to get machine-readable MicroPython API for particular firmware variant?
aivarannamaa
Post by aivarannamaa » Tue Dec 26, 2017 8:06 am
Hi!
I want to enhance MicroPython support in my Python IDE Thonny (currently it only supports Micro:bit).
One aspect of the support would be code completion in scripts. It would be rather easy to do with jedi if I had bunch of Python files corresponding to MicroPython modules containing stubs of the functions (preferably together with docstrings). For add-on libraries I could use the actual Python source, but the problem is with built-in modules.
How can I generate these scripts for each Micropython variant (device * version)? Can I somehow use the source of the docs? The main source?
Do you see other options for providing code completion in scripts (as opposed to dynamic completion in the REPL)?
Aivar Annamaa
https://thonny.org
pfalcon
Re: How to get machine-readable MicroPython API for particular firmware variant?
Post by pfalcon » Tue Dec 26, 2017 12:39 pm
Build unix coverage version ("make coverage"). Then:
$ ./micropython_coverage
MicroPython v1.9.3-183-ge37ccfe59-dirty on 2017-12-16; linux version
>>> import sys
>>> help(sys)
object <module 'sys'> is of type module
  __name__ -- sys
  path -- ['', '/home/pfalcon/.micropython/lib', '/usr/lib/micropython']
  argv -- []
  version -- 3.4.0
  version_info -- (3, 4, 0)
  implementation -- (name='micropython', version=(1, 9, 3))
  platform -- linux
  byteorder -- little
  maxsize -- 9223372036854775807
  exit -- <function>
  stdin -- <io.TextIOWrapper 0>
  stdout -- <io.TextIOWrapper 1>
  stderr -- <io.TextIOWrapper 2>
  modules -- {}
  exc_info -- <function>
  getsizeof -- <function>
  print_exception -- <function>
As usual, not much different than with CPython, adjusted for "micro" in MicroPython.
Awesome MicroPython list
aivarannamaa
Post by aivarannamaa » Wed Dec 27, 2017 9:55 am
I'm afraid I don't understand your advice. I see how I can fetch the list of modules and list of functions, but what about signatures?
Aivar Annamaa
https://thonny.org
josverl
Post by josverl » Fri Jan 05, 2018 2:49 pm
If you run the below on the board and capture the output then you should be able to get the basics
import sys
sys.implementation.name
sys.implementation.version
sys.implementation
sys.platform
this will return something like:
'micropython'
(1, 9, 3)
'esp32'
If you need to get the details of the build, then the only way I know of is to send a Ctrl-D ;) to be board, that will trigger a REPL reset
and then on most firmwares you get some additional info on the welcome prompt
MicroPython v1.9.3-220-g7a9a73ee on 2017-12-27; ESP32 module with ESP32
HTH
Post by dhylands » Fri Jan 05, 2018 3:24 pm
Typo: Control-D does a soft reset and shows the banner (Control-B is used to end the raw repl and switch back to the "friendly" repl).
