Hi guys ,
Very new to Python and Micropython, I need to retrieve values from a html form (textboxes).
My form is pretty simple
def handle_root(client):
myform = """
<form action="save_reco" method="post">
<input type="text" name="firstname" />
<br/>
<input type="text" name="lastname" />
<br/>
<input type="submit" value="Send" />
</form>
send_response(client,myform)
def send_response(client, payload, status_code=200):
client.sendall("HTTP/1.0 {} OK\r\n".format(status_code))
client.sendall("Content-Type: text/html\r\n")
client.sendall("Content-Length: {}\r\n".format(len(payload)))
client.sendall("\r\n")
if len(payload) > 0:
client.sendall(payload)
my save_reco function looks like (it's based on several examples from the net).
def handle_save_reco(client, request):
match = ure.search("firstname=([^&]*)&lastname=(.*)",request)
print(match.group(0).decode("utf-8")
print(match.group(1).decode("utf-8")
def start(port=80):
addr = socket.getaddrinfo('0.0.0.0', port)[0][-1]
global server_socket
server_socket = socket.socket()
server_socket.bind(addr)
server_socket.listen(1)
client, addr = server_socket.accept()
client.settimeout(5.0)
request = b""
while not "\r\n\r\n" in request:
request += client.recv(512)
except OSError:
pass
url = ure.search("(?:GET|POST) /(.*?)(?:\\?.*?)? HTTP", request).group(1).decode("utf-8").rstrip("/")
except:
url = ure.search("(?:GET|POST) /(.*?)(?:\\?.*?)? HTTP", request).group(1).rstrip("/")
if url == "":
handle_root(client)
elif url == "save_reco":
handle_not_found(client, url)
client.close()
Problem is the the data comes empty when I submit the form.
I suppose I miss something
Retrieve values from HTML Form
Re: Retrieve values from HTML Form
IN respect of the behaviour of the code you provide, what do you mean by "The data comes empty"?
What parts successfully run (try print statements) and which parts have unexpected behaviour. What is the behaviour?
ure is not directly equivalent to re, by the way, so figuring out if there are any requests, or any posted content, (without all the filtering/regex) would be a good beginning before coming up with patterns which ure CAN handle to filter stuff out.
