Still the same error Sir, "MemoryError: memory allocation failed, heap is locked".
Here is the code:
import pyb,micropython, aswitch
from pyb import LED, Pin, ExtInt
import uasyncio as asyncio
import utime as time
from alcd import LCD, PINLIST
delay = aswitch.Delay_ms()
lcd = LCD(PINLIST, cols = 16)
async def lcd_update():
await asyncio.sleep(1)
ext = pyb.ExtInt('PE7', pyb.ExtInt.IRQ_RISING, pyb.Pin.PULL_UP, callback)
lcd[0] = 'Vibration Detected' if delay.running() else ' '
def callback(_):
delay.trigger(1000)
pyb.LED(4).toggle()
loop.create_task(lcd_update())
loop.run_forever()
So now i tried with a different method, i declared a global variable and whenever ISR is executed, global variable will be set. Depending on this global variable we will be printing on LCD. But for some reason it also didnt work. Below is my code:
#Write a program to interface vibra Sensor board.
data = False
vibra_value = pyb.Pin('PE7',Pin.IN,Pin.PULL_DOWN)
def callback(_):
global data
pyb.LED(4).toggle()
pyb.LED(3).toggle()
pyb.LED(2).toggle()
pyb.LED(1).toggle()
data = True
global data
if data == True:
lcd[0] = "Vibration Detected"
elif data == False:
lcd[0] = " "
data = False
loop.run_until_complete(lcd_update())
So here my global variable is data =0, so as ISR is serviced, data should become 1. As soon as data becomes high, the LCD should print but its not working as data value is not geting updated or Any reason ? or can you improve the above code.
Thank You
