ExtInt not working properly
Re: ExtInt not working properly
Your callback didn't declare data to be global, so it sets a local variable called data which goes out of scope as soon as the callback exits.
I have corrected that mistake and still its not able to display on LCD.
@nikhiledutech I've now had time to investigate this properly. The trigger() method of the Delay_ms class does allocate memory and hence can't be called from an interrupt handler. This is because it calls loop.create_task(coro()). So there is a more general conclusion, that you can't launch a uasyncio coroutine from an interrupt context.
Regarding this general issue I assume the allocation occurs when the generator function runs and instantiates a generator i.e. the coro() call. Because uasyncio.core is designed to be allocation free.
Regarding the specific issue of the Delay_ms class I should be able to modify this so that trigger() is non-allocating. This would be a worthwhile improvement and hopefully I'll have something later this morning.
Apologies for the confusion.
No problem sir.
but cant we use a global variable and update it in ISR. and use that updated variable in another async function to display on LCD.
The code is mentioned in my above post.
#Write a program to interface vibra Sensor board.
thank youimport pyb
import pyb,micropython
from pyb import LED, Pin, ExtInt
import uasyncio as asyncio
import utime as time
from alcd import LCD, PINLIST
lcd = LCD(PINLIST, cols = 16)
vibra_value = pyb.Pin('PE7',Pin.IN,Pin.PULL_DOWN)
data = 0
#async def sensor():
# lcd[0] = "Vibration Detected"
# await asyncio.sleep(1)
def callback(_):
global data
pyb.LED(4).toggle()
pyb.LED(3).toggle()
data = 1
#while data == 1:
# data = 0
ext = pyb.ExtInt('PE7', pyb.ExtInt.IRQ_RISING, pyb.Pin.PULL_UP, callback)
async def lcd_update():
global data
if data == 1:
elif data == 0:
lcd[0] = " "
data = 0
return data
loop.run_until_complete(lcd_update())
Yes you can, and Dave Hylands explained how. Any Python function which is required to modify a global variable needs a global statement in the function body otherwise it creates a local variable with the same name and discards it when the function terminates.
Okay. I get the real issue here. Global variable is working fine but their is some other problem occurring, which i cant find out.
So below is my code :
1) LCD not connected to M4 board, above program works fine and is giving desired O/P (i.e Printing on terminal and LED toggling)
2) LCD connected to M4: Above program don't work, neither its blinking nor, its printing on terminal.
But one think i will like to bring in notice is that I have interfaced LCD properly, as i have tried to print simple character on LCD and it work.
So can anyone help me to find out, whats the error here, is it program or any other erroneous thing happening in background.
thank you
There are two situations now:import pyb
data = 0
async def sensor():
def callback(_):
global data
data = 1
pyb.LED(4).toggle()
pyb.LED(3).toggle()
pyb.LED(2).toggle()
pyb.LED(1).toggle()
async def vibra_sensor():
global data
if data == 1:
print("working")
data = 0
loop.run_until_complete(vibra_sensor())
thank you
I've now pushed an update to aswitch.Delay_ms. The constructor takes an optional arg can_alloc defaulting True. If trigger() is to be called from an ISR, can_alloc should be False. So the following sample should work with the new version.
Thank you for pointing out this issue. Evidently you're the first to have tried this, but it's an entirely valid use-case. I'd appreciate your feedback on whether this works.
import pyb,micropython, aswitch
delay = aswitch.Delay_ms(can_alloc=False)
lcd[0] = 'Vibration Detected' if delay.running() else ' '
def callback(_):
delay.trigger(1000)
pyb.LED(4).toggle()
loop.create_task(lcd_update())
loop.run_forever()
Hello Sir,
Thank you for updating aswitch.py module. But i am facing a problem. It giving me an Attribute error in asyn module. Below is the code and error.
Code:::
Nikhil Komalan
Code:::
Error:
def callback(_):
delay.trigger(1000)
pyb.LED(4).toggle()
loop.run_forever()
So guide me through this.File "asyn.py", line 231, in <module>
AttributeError: 'module' object has no attribute 'CancelledError'
Nikhil Komalan
You have an old version of uasyncio. Please use upip to upgrade it.
Hello Sir,
Good news, code is working properly now. Thanks for the update in the module. Its will truly help people in future.
Now i tried same method to interface touch key sensor and i have few doubts and i tested all that doubts in programming and its working fine but its displaying character little bit slowly on LCD. But i doubt is this the right method, as i am using multiple triggers for each touchkey.
So please kindly go through my code and help to improve or correct it.
Thanks.
The problem is if i tap on " C" key, LED starts toggling but i have to do multiple taps for displaying C on LCD. Any suggestions ?#Interfacing Touch key and displaying key on LCD
#Initialisation
A_delay = aswitch.Delay_ms(can_alloc=False) #Retrigerable timer
B_delay = aswitch.Delay_ms(can_alloc=False) #Retrigerable timer
C_delay = aswitch.Delay_ms(can_alloc=False) #Retrigerable timer
D_delay = aswitch.Delay_ms(can_alloc=False) #Retrigerable timer
lcd = LCD(PINLIST, cols = 16) #LCD_Initalising
A = pyb.Pin('PE7',Pin.IN,Pin.PULL_UP) #a_Input
B = pyb.Pin('PA3',Pin.IN,Pin.PULL_UP) #b_Input
C = pyb.Pin('PA0',Pin.IN,Pin.PULL_UP) #c_Inputd
D = pyb.Pin('PE6',Pin.IN,Pin.PULL_UP) #d_Input
def callback(_):
if A.value() == True:
A_delay.trigger(1000) #Trigerring timer
pyb.LED(1).toggle()
elif B.value() == True:
B_delay.trigger(1000) #Trigerring timer
pyb.LED(2).toggle()
elif C.value() == True:
C_delay.trigger(1000) #Trigerring timer
pyb.LED(3).toggle()
elif D.value() == True:
D_delay.trigger(1000) #Trigerring timer
pyb.LED(4).toggle()
#Main program
async def touchkey_sensor():
ext_A = pyb.ExtInt('PE7', pyb.ExtInt.IRQ_RISING, pyb.Pin.PULL_UP, callback)
ext_B = pyb.ExtInt('PA3', pyb.ExtInt.IRQ_RISING, pyb.Pin.PULL_UP, callback)
ext_C = pyb.ExtInt('PA0', pyb.ExtInt.IRQ_RISING, pyb.Pin.PULL_UP, callback)
ext_D = pyb.ExtInt('PE6', pyb.ExtInt.IRQ_RISING, pyb.Pin.PULL_UP, callback)
lcd[0] = "A" if A_delay.running() else " "
await asyncio.sleep_ms(500)
lcd[0] = " B " if B_delay.running() else " "
lcd[0] = " C " if C_delay.running() else " "
lcd[0] = " D " if D_delay.running() else " "
loop.create_task(touchkey_sensor())
loop.run_forever()
Thanks.
