lcd160cr.py Recipe for target failed
Posted: Mon Jan 29, 2018 4:30 pm
I'm moving to the latest kernel build 1.9.3 but seem to be unable to successfully build for an STM32 board. I am getting the following error:
MPY modules/lcd160cr.py
File "modules/lcd160cr.py", line 1
SyntaxError: invalid syntax
../../py/mkrules.mk:115: recipe for target 'build-PYBV3/frozen_mpy/lcd160cr.mpy' failed
make: *** [build-PYBV3/frozen_mpy/lcd160cr.mpy] Error 1
I'm following the directions to make mpy-cross first using:
make mpy-cross
from the root repository directory as described at https://github.com/micropython/micropyt ... 6a44d44918.
I then am running from the STM32 directory
make BOARD=PYBV3
Is there something obvious that I am overlooking to compile the latest kernel?
Thanks!
make mpy-cross
make BOARD=PYBV3
Thanks!
