Hi we are developing an application that is using micropython and a ESP32.
I'm now working on the initial implementation for the field update, the whole bootloader part will run using esp-idf as basis but I found that the micropython footprint is large for our current situation. We need to reduce it. Is there some documentation that points for the configuration steps? I was studying the build system and believe that I can remove source code there, but also think that it could be a problem that someone already worked and it's a guide that the community may need, since lack of space isn't something new on embedded.
I'm at first asking for advice.
Customising for flash footprint reduction
