timer isr function problem
Posted: Wed Feb 28, 2018 1:47 pm
by wwsheldons
g = Pin(Pin('Y10'), Pin.OUT_PP)
def tick4(timer):
global g
g.value(not g.value())
tim4 = Timer(4, freq=100000)
tim4.callback(tick4)
the program is above, but if I use the Oscilloscope to see the freq of Pin('Y10') , the value is 14.59KHz. so why? it is why not 50KHz.
Re: timer isr function problem
Posted: Wed Feb 28, 2018 3:42 pm
by Roberthh
The code itself looks fine, so it#s most likely that the Python code cannot run that fast. Try lower speeds and see, at what frequency it is not working any more as expeced. If you need higher frequency signals, use PWM.
Posted: Wed Feb 28, 2018 8:42 pm
by chuckbook
Just out of curiosity and not that it would make any sense.
If I try on my pyboard:
from pyb import Pin, Timer
@micropython.viper
def tick(t):
g(not g())
t4=Timer(4, freq=100000)
t4.callback(tick)
I get 50 kHz on Y10 and REPL is still responding.
Posted: Thu Mar 01, 2018 12:40 am
by wwsheldons
chuckbook wrote: ↑Wed Feb 28, 2018 8:42 pm
@micropython.viper
def tick(t):
g(not g())
t4.callback(tick)
no, I get 35.78KHz on Y10 , and REPL is not reponding
Posted: Thu Mar 01, 2018 12:48 am
by wwsheldons
@micropython.viper
def tick(t):
g(not g())
t4.callback(tick)
my whole question is I want to generate a M code in 50KHz, so my program is :
N_seq = 1023
loc = 0
seq = [1,-1,1,1,-1,-1,-1,...]
@micropython.viper
def tick(t):
global loc,N,seq,g
g.value(not (not seq[loc]))
loc = (loc+1) % N_seq
t4.callback(tick)
and then I can get the M sequence on Y10, but I get "ViperTypeError: can't do binary op between 'object' and 'int''" in line "loc = (loc+1) % N_seq"
but 10KHz is OK
Posted: Thu Mar 01, 2018 6:48 am
The problem here is that Viper likes to know the type of variables. Where variables are passed as function arguments you can use Python type hinting to solve this, but this isn't an option in a timer ISR. One solution is to use the Native decorator, but the code won't be as fast. You could do
def tick(t):
func(loc, N_seq)
@micropython.viper
def func(loc: int, N_seq: int):
loc = (loc + 1) % N_seq
but I don't know if the overhead of the function call might negate the advantage of the viper code emitter.
Other optimisations might be possible. Is
N_seq a constant? If so, you could save the time taken by a variable lookup by
declaring it a constant (using micropython.const). Further, if it is always of form 0b1111...11 perhaps this might be faster as there's no implied division operation:
Incidentally are you sure the line
does what you want it to do?
Posted: Thu Mar 01, 2018 1:57 pm
by wwsheldons
its for changing the element in seq to the logic variable, which can be accepted by g.value().
@micropython.viper
as above program , why not set the variable "seq" and "g" in the input parameters. and it can not implement, I print the "loc", its value is always "1"
Posted: Thu Mar 01, 2018 2:31 pm
by Roberthh
in your code snippet, you set
but both not (not (1)) and not (not (-1)) evaluate to True. That's what @pythoncoder was suspicious about, I guess.
If you write:
seq = [1,0,1,1,0,0,0,...]
then you can directly write that into the pin with:
g(seq[loc])
pin(x) is a shortcut for pin.value(x)
Posted: Thu Mar 01, 2018 4:49 pm
Quite
