const() function
Re: const() function
Post by pythoncoder » Thu Dec 18, 2014 7:45 am
Thanks Damian for that clear explanation. Can const() effectively be applied to class variables? It clarifies code to define constants relevant to a single class as class variables.
Damien
Site Admin
Post by Damien » Thu Dec 18, 2014 9:53 am
pythoncoder wrote: Can const() effectively be applied to class variables? It clarifies code to define constants relevant to a single class as class variables.
Yes, const works for class variables and function local variables (the latter could do with further optimisation).
SpotlightKid
Post by SpotlightKid » Thu Apr 09, 2015 9:29 pm
I noticed one thing that doesn't work with const():
NAME = ALIAS = const(42)
NameError: name 'const' is not defined
Which should be perfectly valid Python syntax. Is this intended?
pfalcon
Post by pfalcon » Sat Apr 11, 2015 11:04 am
Is this intended?
Consider yes. Consider "const" as a special feature which works only for syntax of the form "NAME = const(<scalar_value>)".
Awesome MicroPython list
SpotlightKid
Post by SpotlightKid » Sat Apr 11, 2015 12:02 pm
So what if I do:
NAME = const(42)
ALIAS = NAME
Is ALIAS also considered a constant then?
pfalcon
Post by pfalcon » Sat Apr 11, 2015 12:54 pm
No. Only object initialized with a const() function is consider a constant. For ALIAS to be a constant it would need to be:
ALIAS = const(NAME)
And that may work or not as a constant underlyingly. Generally, const() is a hint to MicroPython compiler to consider constant propagation. It's semantics is equivalent to:
const = lambda x: x
(That's also how it should be defined for CPython compatibility).
badi
Post by badi » Tue Dec 08, 2015 4:10 pm
Regarding "using const for class variable":
I define following class
class foo:
    stVar = const(42)
    stVar1=24
    def __init__(self):
        print(self.stVar)
        print(self.stVar1)
        print(foo.stVar)
        print(foo.stVar1)
which gives me:
>>> a =foo()
<class 'foo'>
24
<class 'type'>
24
Why?
badi
Post by dhylands » Tue Dec 08, 2015 6:35 pm
I have have a feeling that this is related to this issue: https://github.com/micropython/micropython/issues/1675
