How to define ctrl-C handler in MicroPython?
liudr
Post by liudr » Sun Apr 08, 2018 1:29 am
For cpython, this is what I have that handles ctrl-C:
    def SIGINT_handler(signal, frame):
        ser.close()
        data_file.close()
        print('Quitting program!')
        sys.exit(0)
    signal.signal(signal.SIGINT, SIGINT_handler)
MicroPython complains about the last line. Is there any way to do similar things in MicroPython besides enclosing the entire script with a try? Thanks.
Re: How to define ctrl-C handler in MicroPython?
Post by OutoftheBOTS_ » Sun Apr 08, 2018 2:41 am
Not sure if there is a way without using try
I pretty much use at least try and finally in every single Micro-Python script because on exit (whether it is an error for just script finishing) resources that were allocated during the script need to be released, like SPI , I2C objects or any other objects. If your script creates a SPI object and doesn't release it then you rerun your script it will create another instance of the SPi object not reuse the one all ready allocated. When you run a Cpython script from the command line i.e python Logger.py when it exits it should auto de-allocate all resources as it exits from python back to the command line. In Micro-Python when the script exits then it returns to the repl not the command line so nothing is de-allocated.
Post by pythoncoder » Sun Apr 08, 2018 7:04 am
@liudr You didn't mention what platform you're running on. MicroPython is primarily targeted at microcontrollers. The concept of a signal is about communication between processes: irrelevant if you're running a single threaded program on bare metal. On bare metal exception handling is the way to intercept ctrl-c.
On the Unix build there is a use case for signal processing. The implementation in micropython-lib looks as if it should handle SIGINT. If you're running the Unix build what error message are you seeing?
liudr
Post by liudr » Sun Apr 15, 2018 3:14 am
Sorry, ESP32 port. I want to have a graceful way to end a script that is running on repl. It's not essential that I had a way to do so. It's on my good-to-have list. Thanks.
Post by pythoncoder » Sun Apr 15, 2018 8:06 am
This shoud work on any MicroPython platform
def foo():
        pass
    foo()
except KeyboardInterrupt:
    print('Got ctrl-c')
finally:
    # Optional cleanup code
Post by dhylands » Tue Apr 17, 2018 2:33 am
I often put something like the following in my program as well:
repl_uart = pyb.UART(6, 115200)
and then in my main loop:
    if repl_uart.any():
        byte = repl_uart.readchar()
        if byte == 3:  # Control-C
            log('Control-C')
            raise KeyboardInterrupt
