GPIO pin output works in REPL, not in main.py
jgriessen
Post by jgriessen » Thu Apr 12, 2018 11:37 pm
I have something wrong here and cannot see it yet.
Here is my program,
boot.py
# boot.py -- run on boot-up
pyb.main('main.py')
main.py
# Define pins so they can be set with a pin reference like:  pin10.value(1) on the fly.
pinA5 = machine.Pin(machine.Pin.cpu.A5, machine.Pin.OUT_PP, machine.Pin.PULL_NONE)
# pinB3 = pyb.Pin(pyb.Pin.cpu.B3, pyb.Pin.OUT_PP, Pin.PULL_NONE)
# pinB4 = pyb.Pin(pyb.Pin.cpu.B4, pyb.Pin.OUT_PP, Pin.PULL_NONE)
# pinB5 = pyb.Pin(pyb.Pin.cpu.B5, pyb.Pin.OUT_PP, Pin.PULL_NONE)
# pinB6 = pyb.Pin(pyb.Pin.cpu.B6, pyb.Pin.OUT_PP, Pin.PULL_NONE)
# pinB7 = pyb.Pin(pyb.Pin.cpu.B7, pyb.Pin.OUT_PP, Pin.PULL_NONE)
# pinB8 = pyb.Pin(pyb.Pin.cpu.B8, pyb.Pin.OUT_PP, Pin.PULL_NONE)
# pinB9 = pyb.Pin(pyb.Pin.cpu.B9, pyb.Pin.OUT_PP, Pin.PULL_NONE)
# pinB10 = pyb.Pin(pyb.Pin.cpu.B10, pyb.Pin.OUT_PP, Pin.PULL_NONE)
# pinB13 = pyb.Pin(pyb.Pin.cpu.B13, pyb.Pin.OUT_PP, Pin.PULL_NONE)
# pinB14 = pyb.Pin(pyb.Pin.cpu.B14, pyb.Pin.OUT_PP, Pin.PULL_NONE)
# pinB15 = pyb.Pin(pyb.Pin.cpu.B15, pyb.Pin.OUT_PP, Pin.PULL_NONE)
count = 0
while ( count < 20):
    pinA5.value(1)
#    pinB5.value(0)
#    pinB3.value(1)
#    pinB4.value(0)
#    pinB8.value(1)
#    pinB9.value(0)
    pyb.delay(200)
    pinA5.value(0)
#    pinB5.value(1)
#    pinB3.value(0)
#    pinB4.value(1)
#    pinB8.value(0)
#    pinB9.value(1)
#    pyb.delay(400)
    count = count + 1
I can cut and paste some commands in the REPL like this:
>>> import machine
>>> import pyb
>>> pinA5 = pyb.Pin(pyb.Pin.cpu.A5, pyb.Pin.OUT_PP, Pin.PULL_NONE)
>>> pinA5.value(1)
>>> pinA5.value(0)
>>> pinA5.value(1)
to get a volts observed output on A5, but the while loop does not make output.
Can you see anything wrong with my code? It's built with v1.9.3 micropython.
John Griessen blog.kitmatic.com
Re: GPIO pin output works in REPL, not in main.py
Post by Roberthh » Fri Apr 13, 2018 7:45 am
Looks not OK. You need a second pyb.delay() in the loop after the second pin.value(). Otherwise you will switch back too fast. That secopnd delay is there but commented out.
jgriessen
Post by jgriessen » Fri Apr 13, 2018 5:17 pm
Thanks for reviewing this Roberthh. Yes I commented that line out by mistake. It might stop me from seeing a brief pulse. I'll fix that.
jgriessen
Post by jgriessen » Fri Apr 13, 2018 5:42 pm
I get a blink program to run now.
Sometimes rshell quits with cannot enter raw repl.
Now I used buffer-size 30 and it seems better -- going through 10 or so repl commands rshell file copy commands.
a soft reset from the REPL is having no effect on the GPIO pin state now and not rerunning main.py
Can that be caused by pyb.delay() blocking it? I don't think so. the GPI pin would be changed after a while..and pyb.delay is not in an infinite loop anymore.
Post by Roberthh » Fri Apr 13, 2018 6:53 pm
I cannot answer that well, because I do not use rshell a lot. The setting of buffer-size=30 was mentioned in various posts as adequate.
It is strange that the device does not reset after Ctrl-D in this simple GPIO test. I had that experience with WiFi & sockets, where had to go through hard reset to get back into an initial state. For that, my main.py always contains the line:
from machine import reset
Just in case, the reset button is out of reach.
Post by dhylands » Fri Apr 13, 2018 9:17 pm
using rshell over serial needs the --buffer-size=30
The reason rshell doesn't always enter the REPL is because Control-C isn't doesn't interrupt the currently running program when using the serial port.
jgriessen
Post by jgriessen » Sat Apr 14, 2018 7:42 pm
Why would soft reset not rerun main.py from the start? I could only get that to happen after a power on.
Post by Roberthh » Sun Apr 15, 2018 7:02 am
From all what I know and experienced, soft reset reruns boot.py and main.py, at least that is the intention. But it may happen that is is not executed. For instance if you run fro SD card, and the SD card is not properly initialized at soft reset. I never have seen that on a PyBoard, but quite often with an ESP8266 and ESP32 port.
