Problems with running umqtt client asynchronously in main.py
Posted: Sun Apr 22, 2018 12:43 pm
by schwinnez
I am trying to asynchronously initialize a umqtt simple MQTT-Client in the main function and also check for new messages in this asynconous task. What i am basically doing in the task is initializing the client and checking for messages as follows:
await asyncio.sleep_ms(100)
client.check_msg()
To run in asynchronously, I am using uasyncio and the following:
loop.create_task(mqtt_facade.run())
loop.run_forever()
When I start the asynchronous Task in the main function, it does not work for some reason. I also have a simple http server, which works in a similiar manner. This http server works also when I am starting it using uasncio from the main.py.
The strange thing is, that when I am starting the MQTT client from the WebREPL, everythings works as expected. Only starting it from the main.py does not work.
Are there some special restrictions on what can be used in the main.py?
Re: Problems with running umqtt client asynchronously in main.py
Posted: Mon Apr 23, 2018 8:41 am
In general there are no restrictions on using main.py to launch a MicroPython program. However there are many situations in which the official MQTT client can block and possibly you're encountering one of these.
An asynchronous MQTT client involves a significant rewrite involving the use of nonblocking sockets. See this solution, which, in addition to being asynchronous, aims to fix other shortfalls in the official version.
Posted: Mon Apr 23, 2018 9:07 am
by schwinnez
I've already thought about using your alternative MQTT Client. ;) But I am still wondering, why something works when launched from the WebREPL but not when launched from the main.py.
I did only experienced this for the MQTT Client. I already tried to change it slightly, but without success :(
Any ideas, what actually is the problem in my case. Is there a built in way to get output from main.py or do I have to implement this on my own?
Posted: Mon Apr 23, 2018 7:53 pm
by kevinkk525
I used the official mqtt once and wrapped it in asyncio. I attached the file below for you, maybe it helps. Just ignore all the functions you don't need. It worked quite well but I changed to the enhanced version of Peter Hinch a while ago as it has a lot more features.
import gc
import json
from pysmartnode import config
from pysmartnode import logging
import uasyncio as asyncio
log = logging.getLogger("MQTT")
gc.collect()
# BUG: reconnecting still makes a recursion from reconnect -> publish -> reconnecty
class mqttHandler:
    def __init__(self):
        self.subscriptions = {}
        self.payload_on = ["ON", True, "True"]
        self.payload_off = ["OFF", False, "False"]
        self.isReconnecting = False
        self._wildcard_subs_found = False
    def init(self, mqttConnectEvent):
        self.mqttConnectEvent = mqttConnectEvent
        self.loop = asyncio.get_event_loop()
        self.retained = []
        self.id = config.id
        self.mqtt = MQTTClient(self.id, config.MQTT_HOST, user=config.MQTT_USER,
                               password=config.MQTT_PASSWORD, keepalive=config.MQTT_KEEPALIVE)
        self.loop.create_task(self.init_async())
    async def init_async(self):
        self.mqtt.set_last_will("home/" + self.id + "/status", "OFFLINE", retain=True)
        self.mqtt.connect(False)
        self.mqtt.set_callback(self.execute_sync)
        self.mqttConnectEvent.set()
        log.setMQTT(self)
        await self.publish("home/" + self.id + "/version", config.VERSION, True)
        await self.publish("home/" + self.id + "/status", "ONLINE", True)
        self.loop.create_task(self.check_msg())
        self.loop.create_task(self.send_ping())
    async def send_ping(self):
        interval = config.MQTT_KEEPALIVE - 10
            await asyncio.sleep(interval)
                self.mqtt.ping()
            except OSError as e:
                print("Error pinging broker: {!r}".format(e))
                if self.isReconnecting == False:
                    await self.reconnect()
                    await asyncio.sleep(1)
    async def login_finish(self, data):
        if self.loginEvent.is_set() == False:
            if "message" not in data:
                print("Message not in data")
                return False
            if type(data["message"]) != dict:
                print("Login config is no dict, either error in dict or no config provided")
            # try:
            #    data["message"]=json.loads(data["message"])
            # except:
            #    print("Could not convert login config to dict")
            #    return False
            print("login", data["message"])
            erg = data["message"]
            config.registerComponents(erg)
            self.loginEvent.set()
            log.warn("Got new login data although logged in")
    # if host is not running, this reboots client on line open_connection (most of the time...)
    async def login(self, loginEvent):
        # await asyncio.sleep(1)
        await self.mqttConnectEvent
        print("logging in")
        print("ram", gc.mem_free())
        self.loginEvent = loginEvent
        await self.subscribe("home/login/" + self.id, self.login_finish)
        log.info("Client version: {!s}".format(config.VERSION))
        await self.publish("home/login", {"command": "login", "id": self.id, "version": config.VERSION})
    async def check_msg(self):
                self.mqtt.check_msg()
                    print("Error checking mqtt messages: {!r}".format(e))
                    pass
            await asyncio.sleep_ms(20)
            # print("checking")
    async def await_retained(self, topic):
        await asyncio.sleep(2)
        if topic in self.retained:
            del self.retained[self.retained.index(topic)]  # probably no retained message available
        #unsubscribe, not added in mqttclient
    def execute_sync(self, topic, msg):  # mqtt library only handles sync callbacks so add it to async loop
        self.loop.create_task(self.execute(topic, msg))
    async def execute(self, data, msg=None):
        if msg is not None:  # remnant of using this for executionHandler with network sockets
            data = {"topic": data.decode(), "message": msg.decode()}
            data["message"] = json.loads(data["message"])
        except:
            pass
        if "topic" not in data:
            log.error("No topic found in data")
            return "ERROR: No topic"
            log.error("No message found in data")
            return "ERROR: No message"
        topic = data["topic"]  # this is the original topic, data["topic"] is the working topic
        if self._wildcard_subs_found:
            for subs in self.subscriptions:
                if subs.rfind("/#") != -1:
                    if topic.find(subs[:-1]) != -1:
                        data["topic"] = subs
                        break
        if data["topic"] in self.retained:
            ending = "/set" if data["topic"].rfind("#") == -1 else ""
            if data["topic"] + ending in self.subscriptions:
                    if type(self.subscriptions[data["topic"] + ending]) != dict:
                        callback = self.subscriptions[data["topic"] + ending]
                        await callback({"message": data["message"], "topic": topic, "retained": True})
                        for callback in self.subscriptions[data["topic"]]:
                except Exception as e:
                    log.error("Error executing retained mqtt topic {!r}: {!s}".format(data["topic"], e))
                if self._wildcard_subs_found == False or data["topic"].rfind("#") == -1:
                        del self.retained[self.retained.index(data["topic"])]
                    except:
                        pass
                return True
                #log.warn("Got retained message for topic {!r} but did not subscribe to {!r}/set")
                return False
        if data["topic"] not in self.subscriptions:
            return True
        if type(self.subscriptions[data["topic"]]) != list:
                erg = await self.subscriptions[data["topic"]]({"message": data["message"], "topic": topic})
                # so that an integer 0 is interpreted as a result to send back
                if (type(erg) == int and erg is not None) or erg == True:
                    if erg == True and type(erg) != int:
                    if topic.rfind("/set") != -1:
                        topic_a = topic[:topic.rfind("/set")]
                        await self.publish(topic_a, erg, retain=True)
                erg = False
                log.error("Error in function for topic {!r}: {!s}".format(topic, e))
                    erg = await callback({"message": data["message"], "topic": topic})
                    log.error("Error in function for topic {!r}: {!s}".format(data["topic"], e))
                    erg = False
        return erg
    async def __resubscribe(self):
        for topic in self.subscriptions:
                self.mqtt.subscribe(topic)
            except:
                print("error resubscribing")
    async def subscribe(self, topic, callback):  # only async callbacks allowed
        if topic not in self.subscriptions:
            if topic.find("/set") != -1:  # subscribe to topic without /set to get retained message
                self.retained.append(topic[:topic.find("/set")])
                    self.mqtt.subscribe(topic[:topic.find("/set")])
                except:
                    log.error("Could not subscribe to topic {!r}".format(topic[:topic.find("/set")]))
                self.loop.create_task(self.await_retained(topic[:topic.find("/set")]))
            if topic.find("/#") != -1:
                self._wildcard_subs_found = True
                self.retained.append(topic)
                    erg = True
                    log.error("Could not subscribe to topic {!r}: {!s}".format(topic, e))
                    erg = False
                self.loop.create_task(self.await_retained(topic))
                    erg = True
                except:
                    erg = False
            if erg == True:
                self.subscriptions[topic] = callback
                return True
                    del self.retained[self.retained.index(topic[:topic.find("/set")])]
                except:
                    pass
                    except:
                        pass
                log.critical("Could not subscribe to topic {!r}".format(topic))
                return False
            if self.subscriptions[topic] == callback:
                log.warn("Subscription {!r} with callback already registered")
                return True
                if type(self.subscriptions[topic]) == str:
                    self.subscriptions[topic] = [self.subscriptions[topic]]
                    self.subscriptions[topic].append(callback)
                    return True
                    if callback not in self.subscriptions[topic]:
                        return True
                        return True
    async def unsubscribe(self, topic, callback=None):
        # not supported by mqtt client library
        # if type(self.subscriptions[topic])==str or callback is None:
        #    erg=self.mqtt.unsubscribe(topic)
        #    if erg==False:
        #        log.error("Could not unsubscribe topic {!r}, doing it internally".format(topic))
            log.warn("Topic {!r} not subscribed".format(topic))
            return True
                if callback:
                        del self.subscriptions[topic]
                        return True
                        log.warn("Different callback registered to subscription {!r}".format(topic))
                        return False
                    return True
                if callback:
                    if callback in self.subscriptions[topic]:
                        del self.subscriptions[topic][self.subscriptions[topic].index(callback)]
                        return True
                        log.warn("Callback not registered to topic {!r}".format(topic))
                        return True
                    return True
    async def reconnect(self):
        i = 0
        self.isReconnecting = True
                await self.__resubscribe()
                return True
                # can't use log as mqtt unavailable
                print("Error reconnecting to mqtt broker: {!r}".format(e))
                await asyncio.sleep(2 * i)
                i = i + 1 if i < 600 else 600
            finally:
                await self.publish("home/" + self.id + "/status", "ONLINE", retain=True)
    async def publish(self, topic, message, retain=False):
                return self.mqtt.publish(topic.encode(), str(message).encode(), retain)
                print("Error publishing to mqtt broker: {!r}".format(e))
    def __getTopic(self, attribute, command=False, home=None, device_id=None):
        home = home or (config.MQTT_HOME if hasattr(config, "MQTT_HOME") else "home")
        device_id = device_id or config.id
        topic = "{}/{}/{}".format(home, device_id, attribute)
        if command:
            topic = "{}/set".format(topic)
        return topic
    def scheduleSubscribe(self, topic, callback):
        self.loop.create_task(self.subscribe(topic, callback))
mqtt = mqttHandler()
Posted: Mon Apr 23, 2018 8:25 pm
by schwinnez
Just changed my code again with some input from your script and now it seems to be working. I still don't know what change made the difference but I'll try to figure it out. I will keep you informed. I am currently using non-blocking check_msg from MQTT client with periodically calling
which seems to work. Of course, this is not a perfect way for concurrently running MQTT and HTTP server, but for my purposes it is sufficient at the moment.
Posted: Wed Jul 27, 2022 8:43 pm
by Jibun no kage
Updated script? Post it here?
Posted: Thu Jul 28, 2022 8:36 am
If asynchronous operation is important mqtt_as is a proven solution.
