OSError: [Errno 5] EIO while using I2C
nikhiledutech
Post by nikhiledutech » Wed May 02, 2018 10:43 am
I am trying to write and read data from I2C based EEPROM. When i try the same code from the serial terminal it runs fine and it dont give me error.
But when i try to execute same code from main.py file i get the following OS Error "OSError: [Errno 5] EIO" .
Below i have given my code.
from pyb import I2C, Pin
#I2C Initialisation
i2c = I2C(1,I2C.MASTER, baudrate = 100000)
#Write data "A" to slave address 80
i2c.mem_write("A",80,1,timeout = 5000, addr_size = 8)
#Recieve data into Recieve Buffer
i2c.mem_read(1, 80, 1, timeout = 5000, addr_size = 8)
Have anyone faced the same issue, than please tell how to resolve it ?
fstengel
Re: OSError: [Errno 5] EIO while using I2C
Post by fstengel » Wed May 02, 2018 3:38 pm
Have you tried inserting some delay between I2C initialization and its use? In the past, I had a similar problem on an ESP8266 and a small delay helped a lot. Your code would look like :
import utime
#I2C Initialisation
# And a short delay to wait until the I2C port has finished activating.
utime.sleep_ms(100)
# Etc.
nikhiledutech
Post by nikhiledutech » Thu May 03, 2018 8:35 am
Okay. I tried it, still it gives me same error.
Frida
Post by Frida » Thu May 03, 2018 7:14 pm
When it works from the terminal, try a little delay after your writing, so the eeprom has time to write.
Yes Frida is my watchdog!
nikhiledutech
Post by nikhiledutech » Fri May 04, 2018 4:24 am
I provided delay after write and it worked.
thankyou :)
