My test below (uPython 1.9.x) suggests not, just wanted to confirm, thanks.
>>> rtc.datetime()
(2018, 5, 11, 4, 21, 10, 39, 146)
>>> open('delme2.del', 'w')
<io.TextIOWrapper 2000e100>
>>> rtc.datetime((2010, 5, 11, 4, 21, 10, 39, 146))
>>> open('delme3.del', 'w')
<io.TextIOWrapper 2000e270>
>>> rtc.datetime()
(2010, 5, 11, 4, 21, 10, 48, 20)
>>> os.stat('delme2.del')
(32768, 0, 0, 0, 0, 0, 0, 12873600, 12873600, 12873600)
>>> os.stat('delme3.del')
Does uPython set ST_MTIME on file creation?
Re: Does uPython set ST_MTIME on file creation?
Which board are you using?
The timestamps seem to be modified on a pyboard:
MicroPython v1.9.3-521-gd6cf5c6 on 2018-04-23; PYBv1.1 with STM32F405RG
>>> rtc = pyb.RTC()
>>> rtc.datetime()
(2018, 5, 14, 1, 9, 57, 30, 200)
<io.TextIOWrapper 20003380>
<io.TextIOWrapper 20003a20>
>>> rtc.datetime()
(2010, 5, 11, 4, 21, 10, 54, 202)
>>> import os
(32768, 0, 0, 0, 0, 0, 0, 579607056, 579607056, 579607056)
(32768, 0, 0, 0, 0, 0, 0, 326927444, 326927444, 326927444)
Odd, I'm using PyBoard 1.1, will try again copy pasting your code and report versions more carefully. Thanks.
