I have tried this code yesterday to connect to the WiFi and print the data and it worked. I ran again today but it's not working.
File 1 #main.py
# See https://docs.pycom.io for more information regarding library specifics
from boot import *
from pysense import Pysense
from LIS2HH12 import LIS2HH12
from SI7006A20 import SI7006A20
from LTR329ALS01 import LTR329ALS01
from MPL3115A2 import MPL3115A2,ALTITUDE,PRESSURE
if __name__ == "__main__":
wifi_ssid = 'OnePlus5'
wifi_pass = '123456oa'
con = ConnectionIoT(wifi_ssid,wifi_pass)
if con==True:
print ("Connection established")
py = Pysense()
mp = MPL3115A2(py,mode=ALTITUDE) # Returns height in meters. Mode may also be set to PRESSURE, returning a value in Pascals
si = SI7006A20(py)
lt = LTR329ALS01(py)
li = LIS2HH12(py)
print("MPL3115A2 temperature: " + str(mp.temperature()))
print("Altitude: " + str(mp.altitude()))
mpp = MPL3115A2(py,mode=PRESSURE) # Returns pressure in Pa. Mode may also be set to ALTITUDE, returning a value in meters
print("Pressure: " + str(mpp.pressure()))
print("Temperature: " + str(si.temperature())+ " deg C and Relative Humidity: " + str(si.humidity()) + " %RH")
print("Dew point: "+ str(si.dew_point()) + " deg C")
t_ambient = 24.4
print("Humidity Ambient for " + str(t_ambient) + " deg C is " + str(si.humid_ambient(t_ambient)) + "%RH")
print("Light (channel Blue lux, channel Red lux): " + str(lt.light()))
print("Acceleration: " + str(li.acceleration()))
print("Roll: " + str(li.roll()))
print("Pitch: " + str(li.pitch()))
print("Battery voltage: " + str(py.read_battery_voltage()))
file2: boot.py
from network import WLAN
wlan = WLAN() # get current object, without changing the mode
print ("Connecting....")
def ConnectionIoT(ssid,passwifi):
if machine.reset_cause() != machine.SOFT_RESET:
nets = wlan.scan()
for net in nets:
if net.ssid == ssid:
print('Network found!')
wlan.connect(ssid, auth=(WLAN.WPA2, passwifi), timeout=5000)
while not wlan.isconnected():
machine.idle() # save power while waiting
print('WLAN connection succeeded!')
return True
print ('not connected')
return False
I am getting the following error:
File "<stdin>", line 16, in <module>
File "boot.py", line 9, in ConnectionIoT
OSError: the requested operation is not possible
OSError: the requested operation is not possible Pysense
Re: OSError: the requested operation is not possible Pysense
What platform are you running on?
In general it's bad practice to put code in boot.py. It simplifies debugging if you minimise main.py too. Put your code into your own module(s) e.g. mymodule.py. Then you can test it by issuing
When it's working you can make it run automatically by editing main.py to read
Even my biggest projects have a one-line main.py.
Making those changes won't necessarily fix your problem but it will make it easier to locate.
>>> import mymodule
import mymodule
