Hi, I am new to MQTT. I have it working with my ESP32 broad with my windows (or Rasb) as Mqtt broker.
wondering if it is possible to have the same ESP32 micro controller to be a mqtt broker (running Micro Python on it)
If so, any direction on how to do this?
Thanks,
James
MIcropython as MQTT broker
Re: MIcropython as MQTT broker
I don't think this has been done. It would be quite involved and I'm not sure there would be much point. Why not just run mosquitto on a Raspberry Pi?
Thanks pythoncoder for the reply. I was just wondering. My goal was to eliminate at least one hardware from the system
If your connected to the internet then their is always cloud brokers
But the thing is that you may want (like I actually do):
1. To have a system independent of cloud brokers simply because internet is not an option. For agriculture projects, you have situations where internet is not feasible because its either too far away from the nearest internet provider and they simply wont offer you internet - or because its just not worth it paying for internet only to be used for multiple tiny modules to communicate effectively together!
2. Custom boards with custom sizes for custom enclosures cannot always make use of the bulky raspberry pi. Sure enough you could now use the MicroPI but once again that a board on its own that needs to be "inserted" into your custom board. Perhaps its more ideal to have just 1 board and so raspberry pi is not an option either.
I was asking myself the same question that james_km69 asked
In my case I was actually searching for a MQTT broker library for the ESP-IDF SDK to be used with ESP32 hardware, but even micropython would have done the trick.
I've done some research and unfortunately there is no easy existing solution...
I'm working on a IoT project that has some restrictions (much like the latest xenobius post), and I'm thinking of going in the following direction: the devices will "speak" between them using websockets (and not MQTT), and in case there is an active internet connection, the system status will be backed up to a cloud MQTT broker by one "chosen " device, which will be the only MQTT client on the devices network.
In this way, the need for a local broker is removed.
Of course this is no elegant solution, but the alternative would be porting the Mosquitto code to ESP-IDF FreeRTOS....
Andrea
Andrea
EDIT: just FYI, a starting solution does exist for ESP-IDF (not Micropython), using a library called mongoose
The company who develops mongoose also proposes a full embedded firmware called Mongoose OS, which is basically an alternative to micropython, having a limited free edition and a full paid commercial edition.
...still not tried the above, but at least a starting point exists!
