microPython board with GPS and GSM/GPRS/LTE ?!?
jedie
Post by jedie » Sun Sep 16, 2018 2:34 pm
What's the best microPython board with GPS and GSM/GPRS/LTE ?
I only found the M5Stack stuff. Any alternatives?
My Destination is a GPS Tracker that will send the position to my server.
loboris
Re: microPython board with GPS and GSM/GPRS/LTE ?!?
Post by loboris » Sun Sep 16, 2018 7:03 pm
You can easily use any ESP32 board (or other MicroPython boards) with any of GSM/GPRS/3G/GPS mini dev boards like SIM5380E, SIM808, SIM868 ...
They are cheap and works wery well (on some you have to be carefull with Tx/Rx levels).
Only Tx, Rx, GND and power are needed to interface them.
I've tested SIM5360E board with gsm module on my MicroPython port and it works very well (The GPS support for those boards will be added soon).
I've also designed an ESP32-WROVER based board with SIM900, SIM800, SIM5300E or SIM7000E (all pin-compatible) + SIM28M (GPS).
The board will be open hardware project and will be available probably in November. It will be fully supported by my MicroPython port.
HermannSW
Post by HermannSW » Mon Sep 17, 2018 11:44 am
jedie wrote:
Mon Sep 17, 2018 7:42 am
... and ESP8266) ...
No sure whether ESP-01 type boards are an option for the project, but if so be sure to get the ESP-01s model with 1MB flash for running full Micropython (592KB).
HermannSW
Post by HermannSW » Mon Sep 17, 2018 3:41 pm
ESP-32 is fine, and ESP-WROOM-02 as well:
https://www.espressif.com/sites/default ... pdf#page=9
ESP-WROOM-02 currently integrates a 2-MB SPI flash.
Ivan de Almeida
Post by Ivan de Almeida » Tue Dec 10, 2019 8:48 pm
Hi Loboris,
I am trying to connect without wifi with a SIM800L card and an ESP-WROOM-32 but I can't install the gsm module. I accessed your link
https://github.com/loboris/MicroPython_ ... o/wiki/gsm, installed ESP-IDF, enabled PPP and PAP support, but didn't find the option → MicroPython → Modules → Use GSM module.
I am entering import gsm, but always returns ModuleNotFoundError: No module named 'gsm'. I'm not finding the gsm.py module in your github either. Would you help me?
Post by pythoncoder » Wed Dec 11, 2019 8:55 am
You are more likely to get his attention in his forum.
