Allright, here's a MCVE:
I'm using the function you suggested in the module pysmartnode.utils.subscriptionHandlers.test:
def b():
b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b();b(); return 0
All packages have empty "__init__.py" files.
Method 1, importing like "from some.package import module":
>>> import gc
>>> import sys
>>> gc.collect(); gc.mem_free(); dir(); sys.modules;
35536
['uos', '__name__', 'main', 'gc', 'sys']
{'main': <module 'main'>}
>>> from pysmartnode.utils.subscriptionHandlers import test
21872
['uos', '__name__', 'main', 'gc', 'sys', 'test']
{'pysmartnode.utils.subscriptionHandlers.test': <module 'pysmartnode.utils.subscriptionHandlers.test'>, 'pysmartnode.utils': <module 'pysmartnode.utils'>, 'main': <module 'main'>, 'pysmartnode.utils.subscriptionHandlers': <module 'pysmartnode.utils.subscriptionHandlers'>, 'pysmartnode': <module 'pysmartnode'>}
>>> del test
>>> del sys.modules["pysmartnode.utils.subscriptionHandlers.test"]
21712
{'pysmartnode.utils': <module 'pysmartnode.utils'>, 'main': <module 'main'>, 'pysmartnode.utils.subscriptionHandlers': <module 'pysmartnode.utils.subscriptionHandlers'>, 'pysmartnode': <module 'pysmartnode'>}
>>> del sys.modules["pysmartnode.utils.subscriptionHandlers"]
21616
{'pysmartnode.utils': <module 'pysmartnode.utils'>, 'main': <module 'main'>, 'pysmartnode': <module 'pysmartnode'>}
>>> del sys.modules["pysmartnode.utils"]
21632
{'main': <module 'main'>, 'pysmartnode': <module 'pysmartnode'>}
>>> del sys.modules["pysmartnode"]
21984
RAM gets released only after unloading the root package "pysmartnode" instead of when unloading the module "test".
Method 2, import like "import some.package.module":
>>> import gc
>>> import sys
35536
>>> import pysmartnode.utils.subscriptionHandlers.test
21872
['uos', '__name__', 'main', 'gc', 'sys', 'pysmartnode']
>>> del pysmartnode.utils.subscriptionHandlers.test
21744
21744
21648
21664
21680
Here's where it gets weird. Method 2, which worked with a different module, now does NOT release RAM at all and it's impossible to unload the root package "pysmartnode".
Second test using a real module that has some useful code in it like this, which does not have external dependencies:
class _subscription:
def __init__(self, values):
self.values = values
self.next = None
class SubscriptionHandler:
def __init__(self, len_structure=1):
len_structure: number of attributes to be saved separately.
identifier does not count to length of structure.
self.ifirst = None
self.__values = len_structure + 1
def get(self, identifier, index):
if index > self.__values:
raise IndexError("Index greater than object tuple length")
if type(identifier) == _subscription:
obj = identifier
obj = self.__getObject(identifier)
if obj is not None:
return obj.values[index]
raise IndexError("Object {!s} does not exist".format(identifier))
def set(self, identifier, index, value, extend=False):
obj = identifier
if obj is not None:
if extend and type(obj.values[index] == list):
obj.values[index].append(value)
elif extend:
raise ValueError("Can only extend a list")
values = list(obj.values)
values[index] = value
obj.values = tuple(values)
def getFunctions(self, identifier):
return self.get(identifier, 1)
def setFunctions(self, identifier, value):
return self.set(identifier, 1, value)
@staticmethod
def matchesSubscription(topic, subscription):
if topic == subscription:
return True
if subscription.endswith("/#"):
lens = len(subscription)
if topic[:lens - 2] == subscription[:-2]:
if len(topic) == lens - 2 or topic[lens - 2] == "/":
# check if identifier matches subscription or has sublevel
# (home/test/# does not listen to home/testing)
return True
return False
def __getObject(self, identifier, get=True):
iObject = self.ifirst
while iObject is not None:
obj_val = iObject.values[0]
if obj_val == identifier:
return iObject
elif get and obj_val.endswith("/#"):
# check if identifier is found in subscription
if identifier[:len(obj_val) - 2] == obj_val[:-2]:
if len(identifier) == len(obj_val) - 2 or \
identifier[len(obj_val) - 2] == "/":
return iObject
iObject = iObject.next
return None
def addObject(self, identifier, *args):
if len(args) + 1 > self.__values:
raise IndexError("More arguements than structure allows")
obj = self.__getObject(identifier, get=False)
if obj is None:
attribs = (identifier,) + args
if iObject is None:
self.ifirst = _subscription(attribs)
return
while iObject.next is not None:
iObject.next = _subscription(attribs)
# raise IndexError("Object with identifier already exists")
self._set(obj, (identifier,) + args)
def _set(self, obj, values):
values_obj = list(obj.values or [None] * self.__values)
for i in range(1, len(values)):
if values_obj[i] is None:
values_obj[i] = values[i]
elif type(values_obj[i]) != list:
values_obj[i] = [values_obj[i]]
values_obj[i].append(values[i])
obj.values = values_obj
def removeObject(self, identifier):
if obj == self.ifirst:
self.ifirst = None
del obj
return
if obj is not None:
while iObject.next != obj:
iObject.next = obj.next
del obj
def print(self):
for obj in self:
print(obj)
def __iter__(self, with_path=False):
# with_path only for compatibility to tree
obj = self.ifirst
while obj is not None:
if with_path:
yield obj, obj.values[0]
yield obj
obj = obj.next
Method 1, importing like "from some.package import module", looks exactly like with the function before:
>>> import gc
>>> import sys
35536
21232
>>> del test
21072
20944
20960
21968
Method 2, importing like "import some.package.module":
>>> import sys
>>> import gc
21328
21824
21712
21680
21696
In this case with a proper module freeing RAM works as described in the first post. Therefore I'd consider this the MCVE, although you could use another module.
