Function with variable parameters in viper emitter
kak
Post by kak » Thu Oct 18, 2018 1:36 pm
Hi.
I want to write a function, that can either read or write directly to memory.
It should have variable parameters, so that:
mem32(address, data)
Writes to memory, while
result = mem32(address)
reads from memory.
The problem is, to be able to access the memory directly, I have to use @micropython.viper, to be able to use pointers.
Does anybody know how to write such a function? As I'm in viper, I obviously can't check a parameter for being 'none', and I've got no idea how to do it in another way.
Thanks in advance.
Re: Function with variable parameters in viper emitter
Post by Roberthh » Thu Oct 18, 2018 1:52 pm
I do not know the answer, unless you have a special "out of band" value for data. If data is a byte value, e.g. 256. Otherwise I would make two functions for reading and writing.
You don't need Viper
Post by pythoncoder » Fri Oct 19, 2018 8:52 am
You can address memory directly without using Viper. See recent discussions of the uctypes module, for example this thread.
