x = const(0)
y = const(1000)
z = 0
while (const(x+y) > z):
z = z + 1
x = const(0)
y = const(1000)
z = 0
z = z + 1
x = const(100)
y = const(1000)
z = 0
z = z + 1
585 >./micropython -v -v c.py
File c.py, code block '<module>' (descriptor: 7f151b05df40, bytecode @7f151b05e2c0 65 bytes)
Raw bytecode (code_info_size=11, bytecode_size=54):
02 00 00 00 00 00 0b 56 00 b6 02 27 26 44 23 00
00 ff 14 80 64 24 b7 02 14 87 68 24 b8 02 80 24
b9 02 35 09 80 1b b9 02 00 81 f1 24 b9 02 1b 09
01 00 14 88 4c 64 01 1b b9 02 00 d8 36 e6 7f 11
5b
arg names:
(N_STATE 2)
(N_EXC_STACK 0)
bc=-1 line=1
bc=6 line=2
bc=12 line=3
bc=16 line=5
bc=19 line=6
00 LOAD_CONST_SMALL_INT 100
03 STORE_NAME x
06 LOAD_CONST_SMALL_INT 1000
09 STORE_NAME y
12 LOAD_CONST_SMALL_INT 0
13 STORE_NAME z
16 JUMP 28
19 LOAD_NAME z (cache=0)
23 LOAD_CONST_SMALL_INT 1
24 BINARY_OP 26 __add__
25 STORE_NAME z
28 LOAD_NAME const (cache=0)
32 LOAD_CONST_SMALL_INT 1100
35 CALL_FUNCTION n=1 nkw=0
37 LOAD_NAME z (cache=0)
41 BINARY_OP 1 __gt__
42 POP_JUMP_IF_TRUE 19
45 LOAD_CONST_NONE
46 RETURN_VALUE
File "c.py", line 6, in <module>
NameError: name 'const' isn't defined
mem: total=3260, current=888, peak=2468
stack: 288 out of 80000
GC: total: 2072832, used: 960, free: 2071872
No. of 1-blocks: 10, 2-blocks: 2, max blk sz: 6, max free sz: 64743
x = const(100)
y = const(1000)
z = 0
c = const(x+y)
while (c > z):
z = z + 1
598 >./micropython -v -v c.py
File c.py, code block '<module>' (descriptor: 7f3eb946ef40, bytecode @7f3eb946f2c0 66 bytes)
Raw bytecode (code_info_size=12, bytecode_size=54):
02 00 00 00 00 00 0c 56 00 b6 02 27 26 44 46 23
00 00 ff 14 80 64 24 b7 02 14 87 68 24 b8 02 80
24 b9 02 14 88 4c 24 ba 02 35 09 80 1b b9 02 00
81 f1 24 b9 02 14 88 4c 1b b9 02 00 d8 36 ec 7f
11 5b
arg names:
(N_STATE 2)
(N_EXC_STACK 0)
bc=-1 line=1
bc=6 line=2
bc=12 line=3
bc=16 line=5
bc=22 line=7
bc=25 line=8
03 STORE_NAME x
09 STORE_NAME y
13 STORE_NAME z
16 LOAD_CONST_SMALL_INT 1100
19 STORE_NAME c
22 JUMP 34
25 LOAD_NAME z (cache=0)
29 LOAD_CONST_SMALL_INT 1
30 BINARY_OP 26 __add__
31 STORE_NAME z
34 LOAD_CONST_SMALL_INT 1100
42 POP_JUMP_IF_TRUE 25
45 LOAD_CONST_NONE
46 RETURN_VALUE
mem: total=3206, current=722, peak=2564
GC: total: 2072832, used: 768, free: 2072064
No. of 1-blocks: 6, 2-blocks: 1, max blk sz: 6, max free sz: 64743
Of course not. The only use for const is *defining* symbolic constants, before const there should be "=", and before it - the name of constant. Also, should be imported properly:It seems you can't use const in the while loop.
from micropython import const
This isn't needed, the sum of constants is a constant:c = const(x+y)
x = const(100)
y = const(1000)
z = 0
while (x + y > z):
z = z + 1
c = const(x+y)
50 LOAD_CONST_SMALL_INT 1100
53 LOAD_NAME z (cache=0)
57 BINARY_OP 1 __gt__
58 POP_JUMP_IF_TRUE 41
c = x + y
50 LOAD_NAME c (cache=0)
54 LOAD_NAME z (cache=0)
58 BINARY_OP 1 __gt__
59 POP_JUMP_IF_TRUE 41
