Use WDT using ESP8266
guyd
Post by guyd » Mon Oct 22, 2018 5:12 pm
I try to use WDT as noted in http://docs.micropython.org/en/v1.9.3/w ... e.WDT.html, where it specifically instruct to input a apatmeter called `timeout` to define max time until next feed. BUT when I write same code as noted I get an error says :
from machine import WDT
>>> wdt=WDT(timeout=2)
TypeError: function does not take keyword arguments
why is that ?
jickster
Re: Use WDT using ESP8266
Post by jickster » Mon Oct 22, 2018 6:07 pm
Firstly your link is not for the ESP8266 but for the WiPy; in this it doesn't matter but be careful cause sometimes there's differences.
Secondly do not expect the documentation to be up to date. Example: I switched to the ESP8266 version http://docs.micropython.org/en/v1.9.4/e ... hlight=wdt yet it has this text
Availability of this class: pyboard, WiPy.
Why put it in the ESP8266 docs if it's not accessible in that module? #shrugemoji
Refer to:
jickster
Post by jickster » Mon Oct 22, 2018 6:22 pm
But wait there's more!
WDT does exist for ESP8266. How do I know? By looking at the C-code (and by the fact that when you attempted to use it, you were able to get SOME response).
I also looked at the the file machine_wdt.c and I do not see how you can set a timeout at all.
The only argument allowed to the constructor is 0 (which is also the default if you leave it blank).
There are two functions: feed, deinit
but I don't see how to set the timeout.
It ?appears? the watchdog is meant for the system's use and not your own use but there should be some way to set the timeout.
#include <string.h>
#include "py/runtime.h"
#include "user_interface.h"
#include "etshal.h"
#include "ets_alt_task.h"
const mp_obj_type_t esp_wdt_type;
typedef struct _machine_wdt_obj_t {
    mp_obj_base_t base;
} machine_wdt_obj_t;
STATIC machine_wdt_obj_t wdt_default = {{&esp_wdt_type}};
STATIC mp_obj_t machine_wdt_make_new(const mp_obj_type_t *type_in, size_t n_args, size_t n_kw, const mp_obj_t *args) {
    mp_arg_check_num(n_args, n_kw, 0, 1, false);
    mp_int_t id = 0;
    if (n_args > 0) {
        id = mp_obj_get_int(args[0]);
    switch (id) {
    case 0:
        ets_loop_dont_feed_sw_wdt = 1;
        system_soft_wdt_feed();
        return &wdt_default;
    default:
        mp_raise_ValueError(NULL);
STATIC mp_obj_t machine_wdt_feed(mp_obj_t self_in) {
    (void)self_in;
    return mp_const_none;
STATIC MP_DEFINE_CONST_FUN_OBJ_1(machine_wdt_feed_obj, machine_wdt_feed);
STATIC mp_obj_t machine_wdt_deinit(mp_obj_t self_in) {
    (void)self_in;
    ets_wdt_disable();
STATIC MP_DEFINE_CONST_FUN_OBJ_1(machine_wdt_deinit_obj, machine_wdt_deinit);
STATIC const mp_rom_map_elem_t machine_wdt_locals_dict_table[] = {
    { MP_ROM_QSTR(MP_QSTR_feed), MP_ROM_PTR(&machine_wdt_feed_obj) },
    { MP_ROM_QSTR(MP_QSTR_deinit), MP_ROM_PTR(&machine_wdt_deinit_obj) },
STATIC MP_DEFINE_CONST_DICT(machine_wdt_locals_dict, machine_wdt_locals_dict_table);
const mp_obj_type_t esp_wdt_type = {
    { &mp_type_type },
    .name = MP_QSTR_WDT,
    .make_new = machine_wdt_make_new,
    .locals_dict = (mp_obj_dict_t*)&machine_wdt_locals_dict,
kevinkk525
Post by kevinkk525 » Mon Oct 22, 2018 6:49 pm
I'm using a software watchdog on the esp8266 using interrupts and uasyncio. Maybe you find it useful:
import gc
import uasyncio as asyncio
from pysmartnode.utils import sys_vars
from sys import platform
gc.collect()
from pysmartnode import logging
class WDT:
    def __init__(self, id=0, timeout=120, use_rtc_memory=True):
        self._timeout = timeout / 10
        self._counter = 0
        self._timer = machine.Timer(id)
        self._use_rtc_memory = use_rtc_memory
        self.init()
        asyncio.get_event_loop().create_task(self._resetCounter())
        if sys_vars.hasFilesystem():
                with open("watchdog.txt", "r") as f:
                    if f.read() == "True":
                        logging.getLogger("WDT").warn("Reset reason: Watchdog")
            except Exception as e:
                print(e)  # file probably just does not exist
                with open("watchdog.txt", "w") as f:
                    f.write("False")
                logging.getLogger("WDT").error("Error saving to file: {!s}".format(e))
        elif use_rtc_memory and platform == "esp8266":
            rtc = machine.RTC()
            if rtc.memory() == b"WDT reset":
            rtc.memory(b"")
    def _wdt(self, t):
        self._counter += self._timeout
        if self._counter >= self._timeout * 10:
                        f.write("True")
                    print("Error saving to file: {!s}".format(e))
            elif self._use_rtc_memory and platform == "esp8266":
                rtc = machine.RTC()
                rtc.memory(b"WDT reset")
            machine.reset()
    def feed(self):
        self._counter = 0
    def init(self, timeout=None):
        timeout = timeout or self._timeout
        self._timer.init(period=int(self._timeout * 1000), mode=machine.Timer.PERIODIC, callback=self._wdt)
    def deinit(self):  # will not stop coroutine
        self._timer.deinit()
    async def _resetCounter(self):
            await asyncio.sleep(self._timeout)
            self.feed()
def hasFilesystem():
return not os.statvfs("")[0] == 0
Kevin Köck
Micropython Smarthome Firmware: https://github.com/kevinkk525/pysmartnode
