Hi All,
I'm trying to write a module for the SparkFun Motor Driver TB6612FNG
I'm struggling to understand how to use the PWM features of the TimerChannel and would appreciate any help I can get.
I'm not sure what to set the freq and pulse_width to, the datasheet mentions a max 100 kHz frequency on the PWM pins but I'm not sure how use that fact.
Once the channel is configured, is the timer.pulse_width_percent the correct way to vary the motor speed?
I've read the following pages but I'm still confused
http://micropython.org/doc/module/pyb/Timer
http://docs.micropython.org/en/latest/l ... #pyb-timer
http://wiki.micropython.org/platforms/b ... r-Examples
Thanks for your help,
Chris
PWM for motor driver
Re: PWM for motor driver
What frequency you use depends a bit on the motor as well as the PWM controller.
Personally, I try to use a frequency above 20 kHZ so that the motor whine is out of the audible range.
Looking at the datasheet, you'll need to pull STBY high, and then use the table on page 4 of the datasheet to set direction.
You'll use the PWM to toggle between CCW/short brake and CW/short brake. So use IN1/IN2 to control the direction/braking and the PWM to control the speed.
Setting channel.pulse_width_percent to zero should correspond to zero speed, and setting pulse_width_percent to 75 should correspond to 75% speed.
You should try to use 2 channels on the same timer, one channel for each motor. That way the PWM cycles will be synchronized. I'd also recommend using one of the center aligned modes. This will effectively divide the frequency in half.
