I'm new to the pyboard and this froum, but I justed wanted to share my first pyboard experiences with you all.
My application, the ArduGuitar, requires SPI and shift registers, so I started with a 74HC595 and the pyboard and WOW was it easy to get that going!
Here's a little video demo.
My goal was to control the outputs of the the shfit reg from the pyboard. It was pretty easy, the idea is:
- create a latch pin and an spi object, and an object to contain the bits that will go to the shift reg
- set the latch pin LOW,
- send the bits
- set the latch pin HIGH,
The code with the wiring can be found my my github page.
Cheers,
Bob
