Command not executed MQTT boot.py
Posted: Sun Jan 06, 2019 2:43 pm
I have a problem with my boot.py file, I created a file with a different "def" for init network, mqtt, lib, etc ...
The ESP32 starts and starts to boot devices, but it will appear that it does not execute all commands:
My boot.py file runs:
print ("INIT NETWORK")
init_network()
print ("UPDATE")
update()
print ("INIT MQTT")
init_mqtt()
My serial port:
UPDATE
### LIBS DOWNLOADED ###
INIT MQTT
### CONNECTED TO INTERNET ###
MQTT CONFIG
I (6164) wifi: pm start, type:0
File "boot.py", line 92, in <module>
File "boot.py", line 37, in init_mqtt
NameError: name 'mac' is not defined
OSError: [Errno 2] ENOENT
MicroPython v1.9.4 on 2018-05-11; ESP32 module with ESP32
(Nothing is received by the MQTT broker)
But i can pas commands one by one in shell and all works great
Anyone can help me ?
Regards
THE DEF COMMANDS IN THE BOOT.PY FILE
init_network()
print ("UPDATE")
update()
print ("INIT MQTT")
init_mqtt()
My serial port:
UPDATE
INIT MQTT
MQTT CONFIG
Regards
# -INIT NETWORK- #
def init_network():
ssid = "XXX"
w_pass = "XXX"
sta_if.active(True)
sta_if.connect(ssid,w_pass)
mac = ubinascii.hexlify(network.WLAN().config('mac'),':').decode()
if (debug == 1):print(mac)
time.sleep(5)
return 0
# -UPDATE- #
def update():
if (install_lib == 1):upip.install('micropython-umqtt.simple')
if (set_time == 1):settime() #Update Time
if (debug == 1):print("### LIBS DOWNLOADED ###")
return 0
# -INIT MQTT- #
def init_mqtt():
if (debug == 1):print("### CONNECTED TO INTERNET ###")
if (debug == 1):print("MQTT CONFIG")
mqtt = MQTTClient("device_id", "XXX",user="XXX", password="XXX", port="1883")
time.sleep(5)
mqtt.connect()
mqtt.publish(mac, VERSION)
return 0
