Binary file when there is no file system
Ephreal
Post by Ephreal » Tue Jan 15, 2019 1:49 pm
Hi
I'm using Micropython on a Nios 2 Softcore from Altera. I somehow need to load a image file into a Flash. I've tried to wrap this file into a Python string which I then could load from the processor it self. However due to how a string is processed in MicroPython this was not possible. There is generated a hash value for every string and the speed and size of this hash string is proportional with the size of the string length it self.
I do not have a files system on this Nios, all python modules are compile from the Memzip folder (no frozen modules though).
Is there a way to compile a binary file which can be imported or access in other ways through the REPL?
Regards
Ephreal
Re: Binary file when there is no file system
Post by dhylands » Tue Jan 15, 2019 8:55 pm
You can store the binary file on the file system if there is enough space.
Otherwise you might want to look at the font code that Peter Hinch (@pythoncoder) did over here:
https://github.com/peterhinch/micropython-font-to-py
which embeds binary font data into a python source file.
