Hello to everyone,
Background:
I have a Micropython port running on a custom STM32F4 microcontroller board. The python script to be executed is loaded into the filesystem, and pyexec_file parses, compiles and executes the script. There is no REPL console.
Question:
In case of any python syntax error, I would like somehow to retrieve the error line and the description of the error (E.g Line 13: Unexpected foo var). How can we extract this information from the c code of the micropython? Is there any variable in the c code of the micropython that holds this kind of information?
Micropython Syntax Analysis
Re: Micropython Syntax Analysis
See definition of pyexec_file which calls parse_compile_execute: the exception is stored in nlr.ret_val and passed to mp_obj_print_exception. If that's not suitable for you there's not much else you can do but implement parse_compile_execute yourself (or adapt it to pass the exception object to your own function or so).
This python code will record the information into a file. So you may also want to look at the implementation of the sys.print_exception function in C.
and I get the following in exception.txt:
# Exception Test
import sys
def foo():
raise ValueError('An error happened')
def bar():
foo()
except ValueError as ex:
with open('exception.txt', 'wb') as f:
sys.print_exception(ex, f)
print('About to call bar')
bar()
File "exc_test.py", line 10, in bar
File "exc_test.py", line 6, in foo
ValueError: An error happened
The problem is the OP is asking about syntax errors, which happen in the parser already so cannot be caught like that. Unless the entire file execution is wrapped which I think can be done by enabling MICROPY_PY_BUILTINS_EXECFILE to get the execfile function. E.g. principle would be
in C:
in my_main_wrapper.py:
or alternatives like:
and then the actual code goes in my_main.py. This still won't leave a trace of exceptions which might occur my_main_wrapper.py though..
in C:
pyexec_file('my_main_wrapper.py')
execfile('my_main.py')
except SyntaxError as e: # could use this to ditinguish between actual syntax errors and everything else
write_exception_to_file(e)
except Exception as e:
import my_main
my_main.foo()
