Can I get current CPU load and memory usage
mhc994
Post by mhc994 » Tue Feb 05, 2019 2:38 am
I work on an ESP32 board. Micropython is so cool as multi-thread is supported. But I wonder if there is a way to check the CPU load and the memory usage when I run my script.
Sorry if this question is too stupid...
ThomasChr
Re: Can I get current CPU load and memory usage
Post by ThomasChr » Tue Feb 05, 2019 11:07 am
You can get all kinds of memory details with the gc module.
Getting the CPU Usage makes no sense because in the uc world a CPU is running "all the time" (this is also true for modern PCs, but the OS sometimes runs a code snippet called "idle loop" which lets the CPU spin without doing anything, that's how the sheduler knows if the CPU is running a program (running) or running the idle loop (doing nothing usefull and ready to do real world)).
