MicroPython on ParticleIO Argon ESP32
ttmetro
Post by ttmetro » Sat Feb 16, 2019 9:06 pm
I've flashed esp32-20180511-v1.9.4.bin to the ESP32 on the ParticleIO Argon using Adafruit's mini-ESP tool. I've successfully flashed other binaries using this tool, so I expect (?) that it flashed MicroPython correctly also. The UART connection between the nRF52840 also seems fine. E.g. I can enter the bootloader on reset and get a valid response.
FYI: this works as expected. I have not done much with it yet, but maybe others find this interesting.
(The original message described a problem I had. Turned out a mistake in the setup.)
Bernhard
FYI: the ParticleIO Argon uses an nRF52840 with an ESP32 attached as a WiFi modem via UART.
Bernhard Boser
Re: MicroPython on ParticleIO Argon ESP32
Post by OutoftheBOTS_ » Sat Feb 16, 2019 9:20 pm
After googling the board it looks like your flashing the firmware to the main processor the nRF52840 not the ESP32
ttmetro
Post by ttmetro » Sat Feb 16, 2019 10:01 pm
No.
The nRF is running MicroPython itself. This is how I access the esp32 which is not directly accessible (Making debugging harder).
Bernhard Boser
