I am trying to wear out a battery to see how long it powers my ESP32. To do this, I wrote a simple program that writes "Still alive" to a website once a minute. However, the program crashes every time it has written the string successfully to the web file. I can't figure out why it works nine times, then fails. Here is the code:
from time import sleep_ms, ticks_ms
import socket
import urequests
import json
SSID="my_ssid"
PASSWORD="my_passwd"
port=100
wlan=None
s=None
def connectWifi(ssid,passwd): #function to connect to the Web
global wlan #declare a WLAN object
wlan=network.WLAN(network.STA_IF) #create a wlan object
wlan.active(True) #Activate the network interface
wlan.disconnect() #Disconnect the last connected WiFi
wlan.connect(ssid,passwd) #connect wifi
while(wlan.ifconfig()[0]=='0.0.0.0'): #wait for connection
sleep_ms(1)
sleep_ms(1000) #hold on for 1 second
url = "my_receiving_php"
headers = {'content-type': 'application/json'}
data = {'message': 'WLAN connected'}
jsonObj = json.dumps(data)
resp = urequests.post(url, data=jsonObj, headers=headers)
return True
def sendmessage(myMessage):
data = {'message': myMessage}
return True
def main():
connectWifi(SSID,PASSWORD)
hitcount = 0
sendmessage("Still alive")
print("Still alive!")
hitcount = hitcount + 1
sleep_ms(60000)
except Exception as e:
f = open('buglog.txt','a')
f.write(e)
f.close()
main()
print("CRASH!\n")
print (e)
f.write(str(e)+"\n")
f.close()
machine.reset()
>>> Running e:\Dropbox\ZEsp32\workSpace\stillalive\stillalive.py
>>> I (3288) phy: phy_version: 4007, 9c6b43b, Jan 11 2019, 16:45:07, 0, 0
Still alive!
Still alive!
Still alive!
Still alive!
Still alive!
Still alive!
Still alive!
Still alive!
Still alive!
CRASH!
object with buffer protocol required
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5060
load:0x40078000,len:8788
ho 0 tail 12 room 4
load:0x40080400,len:6772
entry 0x40081610
I (437) cpu_start: Pro cpu up.
I (437) cpu_start: Application information:
I (437) cpu_start: Compile time: 12:32:34
I (439) cpu_start: Compile date: Feb 14 2019
I (444) cpu_start: ESP-IDF: v3.3-beta1-268-g5c88c5996
I (451) cpu_start: Single core mode
I (455) heap_init: Initializing. RAM available for dynamic allocation:
I (462) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (468) heap_init: At 3FFB92B0 len 00026D50 (155 KiB): DRAM
I (474) heap_init: At 3FFE0440 len 0001FBC0 (126 KiB): D/IRAM
I (481) heap_init: At 40078000 len 00008000 (32 KiB): IRAM
I (487) heap_init: At 40092834 len 0000D7CC (53 KiB): IRAM
I (493) cpu_start: Pro cpu start user code
I (64) cpu_start: Starting scheduler on PRO CPU.
>>> I (5906) phy: phy_version: 4007, 9c6b43b, Jan 11 2019, 16:45:07, 0, 0
Still alive 0
Still alive 1
Still alive 2
Still alive 3
Still alive 4
Still alive 5
Still alive 6
Still alive 7
Still alive 8
╝Traceback (most recent call last):
File "<stdin>", line 45, in <module>
File "<stdin>", line 40, in main
File "<stdin>", line 33, in sendmessage
File "urequests.py", line 111, in post
File "urequests.py", line 56, in request
OSError: 23
MicroPython v1.10-98-g4daee3170 on 2019-02-14; ESP32 module with ESP32
Any help gratefully acknowledged
