Wanting to send data with different intervals
kevinkk525
Re: Wanting to send data with different intervals
Post by kevinkk525 » Fri Feb 22, 2019 10:01 pm
Yeah sorry about that, forgot to reset the timers.
You need the last sleep statement to prevent a "buys loop" (look it up) that uses all CPU time. Of course the pi only supports time.sleep, not time.sleep_ms.
Re internet: If you run a mqtt broker like mosquitto on your raspberry pi, you don't need to have internet access unless you want to access your local lan from the internet.
Re last will: You should read about mqtt. Last will is sent from the broker when the connection to the client is lost.
Kevin Köck
