Hi there,
I've been trying to run a super simple script, where Rshell is used to connect to my pycom board and load a few files onto it. I've run into the issue where the rshell command is executed and the shell is entered, but no further commands are completed. Does anyone know how to script rshell or get a simple batch file to continue on after rshell is called?
Thanks.
Scripting using Rshell?
Re: Scripting using Rshell?
I have previously used rshell's CLI behaviours directly, like this...
https://github.com/vgkits/vanguard/blob ... nd.py#L166
This technique involves manipulating sys.argv to 'pretend' to rshell that it has been invoked with particular command line arguments to perform a task and return. This is different than the invocation which launches a shell and holds on to the interactive tty.
