Dynamically add method to instance
ttmetro
Post by ttmetro » Sun Mar 03, 2019 1:09 am
How do I add a function dynamically to a MicroPython object?
In standard python "MethodType" is used for this, but it seems missing from MicroPython. Is there a workaround?
Thanks,
Bernhard
Bernhard Boser
jickster
Post by jickster » Sun Mar 03, 2019 1:16 am
Obj.thing = function
ttmetro
Re: Dynamically add method to instance
Post by ttmetro » Sun Mar 03, 2019 7:57 pm
I don't think that binds it to the instance. Hence no reference to "self".
I used a global as a workaround. Not pretty, but works.
Bernhard Boser
jickster
Post by jickster » Sun Mar 03, 2019 11:13 pm
ttmetro wrote:I don't think that binds it to the instance. Hence no reference to "self".
Have you actually tried it?
ttmetro
Post by ttmetro » Mon Mar 04, 2019 2:54 am
yes!
Also what I found with a web search is that this is exactly what
MethodType
is for.
Bernhard Boser
stijn
Post by stijn » Mon Mar 04, 2019 8:37 am
Not 100% sure what you mean, can you give an example maybe?
Possibly you mean something like
class Foo:
  pass
def Stuff(obj):
  print('Stuff', obj)
f = Foo()
print(f)
f.stuff = lambda: Stuff(f)
f.stuff()
mattyt
Post by mattyt » Mon Mar 04, 2019 11:04 am
I believe Bernhard is talking about adding a member function to an instance of a class. MethodType is the standard way to do this. It appears to be implemented in the micropython-lib types module.
ttmetro
Post by ttmetro » Tue Mar 05, 2019 12:32 am
Yes, that's what I want:
from types import MethodType
class DynamicTest:
    def __init__(self):
        self.x = 5
    def a(self):
        return self.x
dt = DynamicTest()
def b(self):
    return self.x
dt.b = b
def c(self):
    return self.x
setattr(dt, 'c', MethodType(c, dt))
print('a', dt.a())
# print('b', dt.b())
print('c', dt.c())
Result:
  • a works as expected.
  • b fails: TypeError: function takes 1 positional arguments but 0 were given (also expected)
  • c fails: TypeError: cannot create 'bound_method' instances
a and c work with cpython, b fails (as it should).
So seems like a feature that is missing from MicroPython. Fortunately there is a workaround, at least for my case.
Thanks for all the suggestions!
Bernhard Boser
