esp8266 not booting
esp8266 not booting
I just flashed the newest esp8266-20190125-v1.10.bin firmware to an esp8266, with these commands:
esptool.py --port COM6 erase_flash
esptool.py --port COM6 --baud 115200 write_flash --flash_size=detect 0 esp8266-20190125-v1.10.bin
I can reset/reboot the device multiple times, no problem. However, if I try to copy some files on the flash, then the device works until the next reset ONLY. On the next reset, I only see some "noise" coming out from the serial line.
First I thought that this might be a problem with the flash. Then I have tried another ESP8266 device, and I got the very same results. Then I went back to esp8266-20180511-v1.9.4.bin but I see no difference. The behaviour is the same: if the flash based filesystem is not modified, then the device boots without problem. But if I write something on the flash fs, then it cannot boot after the next reset.
Any idea what can be causing this?
Re: esp8266 not booting
I just opened a brand new WeMos Mini board and it behaves the same: after something was written to the filesystem, it won't boot. It is clearly not a flash memory problem, because it happened on 3 different devices, one of them is brand new.
What method are you using to write files to the filesystem?
I have developed my own program. Basically it executes python statements through the REPL prompt:
- open a file
- write one chunk into the file
- repeat until all data is transferred
- close the file
Please note that there is no error while I upload the files. It is also possible to import the uploaded python modules. The problem only appears when I first reset the device.
- open a file
- close the file
On the brand new device, I see this in at the end of the garbage:
#4 ets_task(40100130, 3, 3fff83ec, 4)
This one has v1.9.4 firmware. On the other devices, everything is just rubbish. They have v1.10
Just to be on the safe side, try uploading files to your esp8266 using one of:
All right. Here is what I have tried:
At this point, I can reset, connect to the REPL prompt and execute commands.
Next step: I have created a test.txt file with "Hello world" in it, and then:
Here is the result:
pip3 install rshell
rshell --port COM6 --baud 115200 cp test.txt /
C:\Python\Projects\MicroPython\firmwares>rshell --port COM6 --baud 115200 cp test.txt /test.txt
Using buffer-size of 32
Connecting to COM6 (buffer-size 32)...
Testing if ubinascii.unhexlify exists ... Y
Retrieving root directories ... /boot.py/
Setting time ... Mar 09, 2019 16:54:44
Evaluating board_name ... pyboard
Retrieving time epoch ... Jan 01, 2000
Unable to copy 'C:\Python\Projects\MicroPython\firmwares/test.txt' to '/test.txt'
you have to do:
rshell --port COM6 --baud 115200 cp test.txt /pyboard/test.txt
Kevin Köck
I also think that with the esp8266 you need to use the -a option with rshell.
c:\Python\Projects\MicroPython\firmwares>rshell --port COM6 --baud 115200 -a cp test.txt /pyboard/test.txt
Testing if ubinascii.unhexlify exists ... b';l\x00d\x9c\xdf|\x00\x8c$\xe0|\x03\x04\x0c\x04\xc4\x0cd\xec\x04c|\xc7\x83\x02\xe4\x1b\x93{\x92c\x8c\x0cb\x8c\xf3og\x9fl\'o\xdc\xe3\xec\x0c#\x1cx\x8c\x8fl{l{$8\xfbg\xe0\x10\x03\x0c\x04\x82\x04l\x0c\x04\x0c\x04\x0c\x0cc\x0c\'\xe3|\x03\xe4l\x04\x8c\x0c\x04c\x84\xfb\'o\xee\x00d\x8c\xc7$`\x03\xd8\x1b\x1b\'ol\x84l \x03\x0f\x03n{\x87\x93\x9bg\x04\x0c\x83cl`\x03`\xf3o\x0c\x04\x0c\x9e\xe0c\x83nl\x84\x04\x8c\xfbg\'\xe7\x00\x0c\x8f\x07dp\xfbg\xe0\x10\x02\x04\x04s\xc4\x9c\x9c\xe3\xe0\x0c\x04\x0c\x04c\x0cn\xe2|\x03ll\x04\x0c\x04c\x8c\xfbg\'\xe7\x00l\xc4\x0cd`\x02\x98\x13\x1bg\'\x0cl`\x03\x07\x03or\xc7\x9b\x92\'\x0c\x0c\x1bl\x93`\x028\xfbg\xe0\x10\x03\x0c\x04r\x84\x9c\xdc\xe3\xe0\x0c\x8e;\x80\x0cc\x0c\'\xe3|\x03\x04\x8c\x04\x87#\xc4\xf2no\xef\x00\x04\x0cd`\x02\x98\x13\x1bgn\x0cd`\x02\x07\x03gs\x8f\xdb\x93o\x0c\x04#\x83\x9b`\x03\x0f;\x93\x9bg\x04\x0cc\x83\x92`\x03\xc4\xe3\x02\xe4\x1b\x83n\xec\x93{\x82\xfbo|\xe4\x04l\x04$ld`\x02\x1cc\x92\x1b\x03\x0c\x9f<\x03s\xdb\x03d\x9c\'\xe0\x0c\x82\'\xe3\x00\x0c$`\x03\x8c\xe3s\xdbl\x84$\x13\x84\x0c\x0c\x04l \x03\x8c\xe3{\x93d\xe4l\x1b\x8c\x0c\x04\x0cd`\x03\xc4\xe3;\x9b$\x0c\x8e\xdf\x00\x8c\x04\x0cd$`\x03sd\x8e\x83r$\x8c\xdf\xe3\x8cb\x04\xc4\x8cb\x1c|\x0c$c\x9c\xe3\x9c\x03b<\x98\x84\xc4\x8c\x04llc\xec\xf3o\xef\xc0\x1bg\'\xe3\x10\x02\x04\x03\x8clg\x9e\x0c\xec\x04\x8c\x04$\xec\x8fll\xc4\x0c\x8e\x8c\x0c\x04l \x03\x80\x02n\xfc\x00\x8c\x9f\xe2\x84c\x04ld\xec\x84\x8f\x13\x04c\x0c\x03\x02\x84\x9f\xe3\xc4c\x0cd\x04\x8cb\x1c{$sdr\xfbg\x9c\xe3\x00\x84\x04\xec\xfbo\xdc\x9f\x80\x80\x03cp\x1bcl\x8e\xc4l\x9c\xccOSError: [Errno 2] ENOENT\r\n\r\nMicroPython v1.10-8-g8b7039d7d on 2019-01-26; ESP module with ESP8266\r\nType "help()" for more information.\r\n>>> '
File "c:\python\python37-64\lib\site-packages\rshell\main.py", line 1249, in connect
ip_address = socket.gethostbyname(port)
socket.gaierror: [Errno 11001] getaddrinfo failed
During handling of the above exception, another exception occurred:
File "c:\Python\Python37-64\Scripts\rshell-script.py", line 11, in <module>
load_entry_point('rshell==0.0.18', 'console_scripts', 'rshell')()
File "c:\python\python37-64\lib\site-packages\rshell\command_line.py", line 4, in main
rshell.main.main()
File "c:\python\python37-64\lib\site-packages\rshell\main.py", line 2820, in main
real_main()
File "c:\python\python37-64\lib\site-packages\rshell\main.py", line 2782, in real_main
connect(args.port, baud=args.baud, wait=args.wait, user=args.user, password=args.password)
File "c:\python\python37-64\lib\site-packages\rshell\main.py", line 1255, in connect
connect_serial(port, baud=baud, wait=wait)
File "c:\python\python37-64\lib\site-packages\rshell\main.py", line 1279, in connect_serial
dev = DeviceSerial(port, baud, wait)
File "c:\python\python37-64\lib\site-packages\rshell\main.py", line 1543, in __init__
Device.__init__(self, pyb)
File "c:\python\python37-64\lib\site-packages\rshell\main.py", line 1333, in __init__
unhexlify_exists = self.remote_eval(test_unhexlify)
File "c:\python\python37-64\lib\site-packages\rshell\main.py", line 1453, in remote_eval
return eval(self.remote(func, *args, **kwargs))
File "c:\python\python37-64\lib\site-packages\rshell\main.py", line 1431, in remote
self.pyb.enter_raw_repl()
File "c:\python\python37-64\lib\site-packages\rshell\pyboard.py", line 187, in enter_raw_repl
raise PyboardError('could not enter raw repl')
rshell.pyboard.PyboardError: could not enter raw repl
