Can I run specify .py file on board via REPL prompt after boot done ?
water
Post by water » Tue Mar 12, 2019 3:20 pm
Can I run specify .py file (e.g aaa.py store on Micropython board , not boot.py or main.py .) via REPL prompt after boot done?
fstengel
Re: Can I run specify .py file on board via REPL prompt after boot done ?
Post by fstengel » Tue Mar 12, 2019 3:36 pm
import aaa
shoud do the trick. note: no .py extension, just the file (module) name...
water
Post by water » Sun Mar 17, 2019 11:40 pm
This can execute once, until reset the board.
I tried
del(aaa)
and
import aaa
again, not work(can't run aaa.py).
Post by dhylands » Mon Mar 18, 2019 3:03 am
You also need to remove it from sys.modules.
See this post: viewtopic.php?f=2&t=413&p=7609
