Serial - bit banging
lukesky333
Post by lukesky333 » Mon Mar 18, 2019 9:06 am
is it possible to read the wakeup bit from the serial port as mentioned here to discover the first byte of a command?
Thanks a lot...
Re: Serial - bit banging
Post by pythoncoder » Mon Mar 18, 2019 1:14 pm
According to the docs machine.UART can read 9-bit characters so I don't see why not.
lukesky333
Post by lukesky333 » Tue May 28, 2019 1:54 pm
I'm using the board ttgo mini32 and it seems, that is impossible to read the 9th bit.
Is there another way to read serial in something like a RAW mode?
Post by OutoftheBOTS_ » Tue May 28, 2019 9:29 pm
Don't quote me on this but I think ESP32 hardware serial only has 8 bit serial
Post by pythoncoder » Wed May 29, 2019 6:56 am
There is no official soft UART implementation. The best option is probably to use hardware which does support it, such as any Pyboard. A soft UART could be written but would probably be restricted to low baud rates because of ESP32 latency issues.
lukesky333
Post by lukesky333 » Wed May 29, 2019 7:31 am
What do you mean with "low baud rates"? I need only 19.2K for 2 UARTs, the third is only for upload and development.
Can you suggest any board for my needs?
  • 2 UARTs (9-bit)
  • possibility to connect a SD-card for logging
  • threading support to log 2 UARTs
  • fast and a lot of memory would be nice
  • as cheap as possible ;-)
Thanks a lot for your support...
Post by pythoncoder » Wed May 29, 2019 7:49 am
A Pyboard (V1.1 or D series). Whether they meet your requirement for "as cheap as possible" is moot.
I would strongly recommend uasyncio rather than threading for reasons covered in the tutorial in this repo.
Writing a soft UART capable of handling two concurrent 19.2Kbaud streams would be a significant challenge and might not be practicable on ESP32. Unless you fancy the challenge and have plenty of time to devote to it, I'd go for the hardware solution ;)
lukesky333
Post by lukesky333 » Wed May 29, 2019 8:47 am
I've allready seen the Pyboard D-series. It's nice but a lot of money. Is there a cheap alternative board too? I think the possibility to get the "9th bit" depends on the chip, not on the board? What is with this one?
Post by OutoftheBOTS_ » Wed May 29, 2019 11:01 pm
The STM32F407 MCUs have 5 UARTS (3 x USART and 2 X UART).
I prefer the STM32F407VGT6 with 1 mb of flash on the MCU and this board has another 16M-BIT of flash on a separate IC and is under $10US https://www.aliexpress.com/item/STM32F4 ... st=ae803_5
I am not sure if anyone has ported MP to this exact board but I know there is ports for STM32F407VET6 black which is the same but with only 512kb RAM on the MCU
From the reference manual the STM32F407 supports 9 bit serial by setting the M bit in the UART control register
UART 9.JPG (32.74 KiB) Viewed 5371 times
lukesky333
Post by lukesky333 » Fri May 31, 2019 11:52 am
Is it possible to use the same MicroPython version like for the STM32F407VET6 or does it need further development for this board?
