Yes on SDRAM, probably not on this particular module. I've written support for SDRAM on both the STM32F429 disco board and the STM32F469i disco board (in C) Repos are available on my github (https:://github.com/ChuckM/stm32f469i and in the contributed code for the libopencm3 examples on the STM32F429 https:://github.com/libopencm3/libopencm3-examples). Looking at the uPython code I can see no reason why it would not be possible to have all of the RAM available.
I've been thinking about doing a port to the STM32F469i-discovery because you could use the RAM, the SD interface for code, and the sweet 800 x 480 LCD display for graphics.
--Chuck
SDRAM module
Re: SDRAM module
The STM32F769DISC build already has preparations for SDRAM, but it's disabled by default. It also has an 800x480 LCD and might be very similar to the board you mention (but no code for it yet, as far as I can tell).
Re: SDRAM module
@jcw that is the 'F7' version, the one I have been playing with is the F4 version (the ST32MF469). The '469 has the DSI and MPI hardware so it can drive a larger display with just the two pins.
--Chuck
--Chuck
