UART lost bytes / buffer overflow issue
bandaangosta
Post by bandaangosta » Sun Apr 07, 2019 1:11 am
I have been struggling with an issue for a couple days. I am communicating my WEMOS D1 Mini Lite board to my PC through the onboard USB port (UART0). After understanding* the whole deal with the REPL and UART0, thanks to the good experts here (viewtopic.php?f=15&t=6182), I got stuck at a buffer issue that is actually quite simple, but I could not find any reference in the documentation so I don't know if I am doing something wrong or not.
On the PC side:
# Master device (host) main program
import serial
slave = serial.Serial('/dev/ttyUSB0', 115200, timeout=3)
    time1 = time.time()
        time2 = time.time()
        if time2 - time1 > 1:
            time1 = time2
            packet = '[{:.3f}] ABCDEFGHIJKLMNOPQRSTUVWXYZ\n'.format(time1)
            print('Sending packet: {}'.format(packet), end='')
            slave.write(packet.encode('utf-8'))
        # Uncomment following line to reduce host CPU usage
        time.sleep(.1)
except KeyboardInterrupt:
    print('Ctrl+C was pressed')
finally:
    if slave.is_open:
        slave.close()
        print(' Serial connection was closed')
On execution:
Sending packet: [1554597073.694] ABCDEFGHIJKLMNOPQRSTUVWXYZ
Sending packet: [1554597074.697] ABCDEFGHIJKLMNOPQRSTUVWXYZ
Sending packet: [1554597075.699] ABCDEFGHIJKLMNOPQRSTUVWXYZ
Sending packet: [1554597076.702] ABCDEFGHIJKLMNOPQRSTUVWXYZ
^CCtrl+C was pressed
On the ESP8266 side, I disable REPL on UART0 on boot.py with
uos.dupterm(None, 1)
and use UART1 (Tx only) for debugging with the help of a cheap USB to TTL serial adapter, connected to the PC as well. ESP code is:
# Slave device (ESP8266 board) main program
led = machine.Pin(2, machine.Pin.OUT) # set to 2 for builtin LED in Wemos D1 mini lite
debugger = machine.UART(1, 115200)
def debugPrint(msg):
    debugger.write(str(msg) + '\r\n')
def main():
        uart = machine.UART(0)
        uart.init(115200, timeout=100)
        ticker = time.ticks_ms()
        debugPrint('Entering main loop')
            if uart.any():
                msg = uart.readline()
                debugPrint(msg)
    except Exception as exc:
        debugPrint('Exception was raised')
        debugPrint(type(exc))
        debugPrint(str(exc))
    finally:
        # Blink repeteadly
        for i in range(8):
            led.value(not led.value()) # Toggle LED
            time.sleep(0.1)
# Run main loop
main()
After hard resetting the board, debugging messages show the following once host (PC) script is run:
Entering main loop
b'[1554597073.694 ABCDEFGHIJKLMNPQRSTUVWXYZ\n'
b'[1554597074.697 ABCDEFGHIJKLMNPQRSTUVWXYZ\n'
b'[1554597075.699 ABCDEFGHIJKLMNPQRSTUVWXYZ\n'
b'[1554597076.702 ABCDEFGHIJKLMNPQRSTUVWXYZ\n'
Notice the missing closing bracket and the letter O. So, it appears as if every 16th byte is lost. A buffer overflow maybe?
My solution was to send one byte at a time from the host, adding a short delay between bytes. On the board, package is reconstructed:
PC code:
   time1 = time.time()
        time2 = time.time()
            time1 = time2
            for byte in list(packet):
                slave.write(byte.encode())
                time.sleep(.001)
PC console:
Sending packet: [1554598416.067] ABCDEFGHIJKLMNOPQRSTUVWXYZ
Sending packet: [1554598417.123] ABCDEFGHIJKLMNOPQRSTUVWXYZ
Sending packet: [1554598418.179] ABCDEFGHIJKLMNOPQRSTUVWXYZ
Board code:
        buffer = []
            if uart.any():
                c = uart.read(1)
                if c is not None:
                    if c.decode('utf-8') == '\n':
                        msg = ''.join([x.decode('utf-8') for x in buffer])
                        debugPrint(msg)
                        buffer = []
                        buffer.append(c)
On board (debugging):
Entering main loop
Is this expected behavior or am I hitting a timing or buffering issue due to some error in my code(s)?
Thanks!
*I still don't fully understand REPL redirection/duplication. What is the 2nd parameter of uos.dupterm() for again? I think the documentation could benefit from more examples.
Re: UART lost bytes / buffer overflow issue
Post by pythoncoder » Sun Apr 07, 2019 8:32 am
It is possible that the ESP8266 can't cope with such a high baudrate. I would try testing at (say) 9600 to see if this affects things. I don't know if the ESP8266 port of machine supports the rxbuf UART constructor arg. If it does, try setting the value to a number > your message length.
These tests would give some indication of the cause.
Re dupterm args my interpretation of the docs is that the index arg enables concurrent duplication on more than one uart. Assume u0 and u1 are UART instances, then the following should achieve it on platforms supporting more than one slot:
uos.dupterm(u0)  # on slot 0
uos.dupterm(u1, 1)  # slot 1
Note I haven't actually tried this.
bandaangosta
Post by bandaangosta » Sun Apr 07, 2019 8:54 pm
Thanks, Peter. You just led me in the right direction about the rxbuf setting.
First I tried with 9600 baudrate, but same results.
As I am disabling the REPL on UART0, I have no access for the REPL on USB. But after enabling and setting webrepl, I could try a test code by Dave Hylands on viewtopic.php?f=2&t=1741&p=33589&hilit= ... fer#p33589
This gave me the full UART0 default settings given my uart.init(115200, timeout=100):
events = [(UART(0, baudrate=115200, bits=8, parity=None, stop=1, rxbuf=15, timeout=100, timeout_char=1), 1)]
I then figured out I could have obtained the same information by just doing:
>>> uart=machine.UART(0)
>>> uart
UART(0, baudrate=115200, bits=8, parity=None, stop=1, rxbuf=15, timeout=0, timeout_char=1)
At least I got to learn how the select.poll() method works.
So, after setting the UART with uart.init(115200, timeout=100, rxbuf=CUSTOM_RX_BUF), everything works fine:
CUSTOM_RX_BUF = 15 (default). Fails.
Entering main loop
b'[1554664963.371 ABCDEFGHIJKLMNPQRSTUVWXYZ\n'
b'[1554664964.373 ABCDEFGHIJKLMNPQRSTUVWXYZ\n'
b'[1554664965.375 ABCDEFGHIJKLMNPQRSTUVWXYZ\n'
CUSTOM_RX_BUF = 100 . Works as expected.
Entering main loop
b'[1554665017.527] ABCDEFGHIJKLMNOPQRSTUVWXYZ\n'
b'[1554665018.529] ABCDEFGHIJKLMNOPQRSTUVWXYZ\n'
b'[1554665019.532] ABCDEFGHIJKLMNOPQRSTUVWXYZ\n'
So, this effectively solves my problem.
There is still something I don't get. CUSTOM_RX_BUF=15 (default value) explains the lost characters in my tests in the exact positions they appeared. However, CUSTOM_RX_BUF = 16 is enough to solve the issue (I used 100 above just to emphazise the bigger value). From your suggestion of "try setting the [rxbuf] value to a number > your message length", I was expecting that CUSTOM_RX_BUF = 16 would just move the "missing" character one space to the right, given my test string.
Post by pythoncoder » Mon Apr 08, 2019 7:02 pm
I would have expected that too. Puzzling.
Logician
Post by Logician » Wed May 13, 2020 9:30 pm
Thanks for this post!
I spend hours (and hours) trying to figure out why I was only ever getting 15 bytes in my rx buffer. Turns out that's the default limit when not specified in the UART instantiation.
kumy
Post by kumy » Fri Oct 16, 2020 8:30 am
I hit that too. Setting RXBUF to 16 solved my issue.
Thanks!!!
