I2C multiplexer library?
asuagar
Post by asuagar » Mon Apr 15, 2019 10:16 am
Is there a Micropython library for the TCA9548A or another multiplexer device? There is a library for the TCA9548A in CircuitPython. However, I am afraid that it will not work in MicroPython. Is there other way for multilplexing using MicroPython?
Thanks & regards!
Re: I2C multiplexer library?
Post by Roberthh » Mon Apr 15, 2019 2:00 pm
Circuitpython is a Micropython variant. The only thing to adapt is typcially the way it speaks to I2C. There are minor differences in the I2C API. I have sucessfully ported Adafruit libraries, and it was usually easy.
doublevee
Post by doublevee » Sun Apr 21, 2019 10:50 am
I have been using this mutliplexer in a product I am building and it is very easy to use. I'm not sure it needs a library at all? You select the I2C address for the mux using 3 external pins (can be IO driven or just hard wired). You then just write a single command to that address to select the output channel of the mux. The mux remains on that channel until either a power cycle or you issue a new channel command.
In brief, once you have your mux setup, it's a very small amount of code to add to select a particular device - almost a single line depending on your use case.
Happy to help further if needs be. I'm no expert at all but happy to try and help if needed.
sequel
Post by sequel » Thu Oct 17, 2019 2:15 pm
I am trying to use a tca9548a to drive 2 temperature/humidity sensors (si7021) on an esp32 board, using the CircuitPython code (https://github.com/adafruit/Adafruit_Ci ... n_TCA9548A) and, i have no success so far.
Here's what i have been doing so far :
import si7021
import tca9548a
scl_pin=22
sda_pin=21
i2c=machine.I2C(-1, machine.Pin(scl_pin), machine.Pin(sda_pin))
tca=tca9548a.TCA9548A(i2c)
As soon as i am trying to reach a sensor like this :
si7021_obj1=si7021.SI7021(tca[0])
I am getting :
  File "/lib/si7021.py", line 46, in __init__
  File "/lib/si7021.py", line 50, in init
  File "/lib/si7021.py", line 87, in reset
  File "/lib/si7021.py", line 66, in _command
  File "/lib/tca9548a.py", line 39, in writeto
OSError: [Errno 19] ENODEV
I am not sure how to proceed to debug this further. The sensors are working great without the multiplexer.
@ doublevee
Could you kindly post some code snippets on how you manually use this multiplexer? That would help me troubleshoot further.
Thanks in advance.
sequel
Post by sequel » Thu Oct 17, 2019 5:35 pm
Finally got it working with this simple code, if that can help someone :
tca9548a_test.py
import ustruct
scl_pin=22
sda_pin=21
class TCA9548A():
    def __init__(self,address):
        self.address=address
        self.bus=machine.I2C(-1, machine.Pin(scl_pin), machine.Pin(sda_pin))
    def switch_channel(self,channel):
        self.bus.writeto(self.address,ustruct.pack('B',1 << channel))
and then :
import tca9548a_test
import si7021
tca=tca9548a_test.TCA9548A(0x70)
for channel in range(0,2):
    tca.switch_channel(channel)
    sensor=si7021.SI7021(tca.bus)
    print('humidity on sensor # {} = {}%'.format(channel, sensor.humidity()))
    print('temperature on sensor # {} = {}°C'.format(channel, sensor.temperature()))
will give something like this :
humidity on sensor # 0 = 50.7894%
temperature on sensor # 0 = 19.28095°C
humidity on sensor # 1 = 57.13706%
temperature on sensor # 1 = 19.32385°C
Cheers!
