This seems to be a quirk? of the unix version of micropython. I was able to reproduce this by creating a file iceCream.py that contained:
and copying that into the modules directory and rebuilding micropython. As you did, I get:
637 >./micropython
MicroPython v1.10-290-g8402c26cf-dirty on 2019-04-30; linux version
>>> import iceCream
Executing iceCream.py
and with a main.py that contained:
then I get:
637 >./micropython main.py
File "main.py", line 4, in <module>
ImportError: no module named 'iceCream'
The next thng I did was to print sys.path for each of these cases:
638 >./micropython
>>> import sys
>>> print(sys.path)
['', '/home/dhylands/.micropython/lib', '/usr/lib/micropython']
and
640 >./micropython main.py
['/home/dhylands/Dropbox/micropython/micropython/ports/unix', '/home/dhylands/.micropython/lib', '/usr/lib/micropython']
and this shows us the difference. The empty string in sys.path is where the interpreter will look for frozen modules, and when executing main.py there is no empty path added to sys.path. If we add it ourselves:
import sys
sys.path.insert(0, '')
print(sys.path)
import iceCream
then everything works as expected:
646 >./micropython main.py
['', '/home/dhylands/Dropbox/micropython/micropython/ports/unix', '/home/dhylands/.micropython/lib', '/usr/lib/micropython']
