Structured prog & global variables
In my ignorance I don't know if this is hardware specific or not. Using an ESP32 spiram.
I have a main program which is getting a little messy, so I have started to use extra files which have function def's in. In the main program I 'import from' so I can use them.
All goes well until I want to manipulate variables which have been declared in the main file. All that I have read indicates that if I declare the variables as 'global' within the external function, before I use them, then they can be accessed.
Well, whatever I do, I get errors thrown up, in that the variable is not recognised.
I would appreciate any guidance here ….. I have done my best in terms of searching … but to no avail.
As a second related question, I have also got a socket (udp) set up in the main program, which retrieves sent data. This all works fine.
In the same 'external' function with the global variable issue, I would like to refer to the socket for sending data out. This also fails.
All works well if I place the function back in the main section, but it would be nice to structure the program in a more orderly fashion.
Thanks for any help.
D.R.
D.R.
Re: Structured prog & global variables
It is best if possible to avoid global variables where possible.
The cleanest way to have many functions access a common variable is to use a class and then use the prefix self. before any variables that you want to be accessible from all the other functions/methods of the class.
see https://www.tutorialspoint.com/python/p ... bjects.htm
Thank you for that …. still learning.... only a few years to go!
Off to do some reading then.
Thanks again
Thanks again
The advice about avoiding globals is undoubtedly correct. Access is relatively slow. But there are other reasons rooted in general programming practice which you can research online.
It's worth understanding Python's scoping rules. If a module has a global name (whether for data or for an object such as a function) the name's visibility to other modules depends on how the module is imported.
my_module:
The need for a global statement arises if a function needs to modify a global variable. Consider the following
Without the global statement foo() would create a local variable bar and set that to 99 leaving the global bar unchanged: in other words foo() would do nothing useful. For some reason when I was learning Python this took me a while to grasp.
There is an option to import all exposed names from a module with
This should be used with care as it can populate your local namespace with unexpected names and can be a source of evil bugs (say if the author has redefined a Python built-in function). Only use if you understand the module you're importing.
my_module:
bar = 42
def foo():
return bar
import my_module
my_module.foo() # Access by prepending the module name
my_module.bar = 99
print(my_module.foo()) # 99
from my_module import foo
foo()
bar = 99 # Will create a new variable local to the current module
print(foo()) # Will return 42
bar = 42
def foo():
global bar
bar = 99
from some_module import *
Thanks for taking the time ….. these snippets really help get a better understanding ….
We know that using global variables isn't a good practice. But it's sometimes convenient and Python permits it.
However I was recently surprised to find that global variables are global to a module not across all modules. Reading the doc teachs me this is normal behavior. So that's ok when you know it, and one more reason to avoid "global" or at least to be (very) careful.
Exemple tested on Python3 on PC and microPython 1.10 on ESP32
Now we define the same function but in a module:
my_module.py :
>>> def foo():
... global bar
... bar = bar + 1
... return bar
>>> bar = 5
>>> foo()
6
my_module.py :
def foo():
global bar
bar = bar + 1
return bar
>>> import my_module
>>> bar = 5
>>> my_module.foo()
File "my_module.py", line 3, in foo
NameError: name 'bar' isn't defined
Actually this is a strength of Python. If you issue
you have a guarantee that the only name added to your namespace is my_module: names within the module a guaranteed not to conflict with your own because you have to prepend them with the module name:
Likewise if you issue
you know exactly which names you've added. Issuing
will populate your namespace with an arbitrary assortment of names. This can have unforeseen consequences. It has its uses, but you need to study the module code.
This is the sort of chaos which your truly global variables might unleash
import my_module
import my_module
x = my_module.foo()
from my_module import foo, bar
from my_module import *
Your my_module.py file should rather contain:JumpZero wrote: ↑Thu May 09, 2019 9:15 amNow we define the same function but in a module:
my_module.py :Code: Select all
def foo(): global bar bar = bar + 1 return bar
>>> import my_module >>> bar = 5 >>> my_module.foo() Traceback (most recent call last): File "<stdin>", line 1, in <module> File "my_module.py", line 3, in foo NameError: name 'bar' isn't defined >>>
bar = 0
def foo():
global bar
bar = bar + 1
return bar
>>> import my_module
>>> my_module.bar = 5
>>> my_module.foo()
6
Hi!
Actually very interesting discussion.
@dhylands you are right the proper way to access the module global variable "bar" is:
"my_module.bar" this avoids confusion, keeping in mind that the main programme global variable "bar" is another variable.
@pythoncoder Yes this is a Python strength: the guarantee of names being uniques in user's namespace when you prepend them with module name. And thanks to pointing out the risks of usingI didn't realize that. Better be careful and use the full name with module name prepending.
And now for the fun: the unleashed sort of chaos
from module import *
jumpzero@penguin:~$ cat my_module.py
bar = 0
def foo():
global bar
bar = bar+1
return bar
jumpzero@penguin:~$ python3
Python 3.5.3 (default, Sep 27 2018, 17:25:39)
[GCC 6.3.0 20170516] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> bar = 3
>>> bar
3
>>> bar
0
>>> foo()
1
>>> bar = 7
>>> bar
7
>>> foo()
2
>>> bar
7
>>> foo()
3
