double precision float on ESP8266
ThomasChr
Re: double precision float on ESP8266
Post by ThomasChr » Wed May 22, 2019 4:51 am
Phew, okay that sound resonable!
Just ask if you have any problems building the firmware!
Post by pythoncoder » Wed May 22, 2019 8:24 am
The Pyboard D SF6W has hardware double precision FP. As far as I know the other ports which implement it do it in software.
Astronomical work definitely needs DP, especially if you get into things like predicting solar eclipses...
glubuluck
Post by glubuluck » Wed May 22, 2019 8:29 am
Thanks, good to know ! But not the same budget.. And actually i can manage with software implementation, since there is no time of computing issue.
pidou46
Post by pidou46 » Fri May 24, 2019 6:31 am
Sometime ago I made some thought, about this subject to build an heliostat.
The best option to me would be:
- port a fixed point precision library to microptyhon( the original one is python 3.1 so it should be quite easy)
- code the astronomic algorithm using this library.
Here is the thread for reference:
viewtopic.php?f=15&t=3405&p=19923#p19923
Finaly, I gived up because single precision was enough for me.
nodemcu V2 (amica)
micropython firmware Daily build 05/31/2016
pidou46
Post by pidou46 » Fri May 24, 2019 3:30 pm
I have made some tests:
I got FixedPoint.py
To avoid an error I remove 'TypeError' from line 248 (I will check later thi point)
"class FXfamilyError(FXexception, TypeError): "
I upload it to my esp32.
import FixedPoint
x=FixedPoint.FXnum=(1)
y=FixedPoint.FXnum=(3)
print(x/y)
0.333333333333333333315
default family is 64bits
I try 128bit adn get an error
nodemcu V2 (amica)
Post by jimmo » Fri May 24, 2019 3:59 pm
The FixedPoint library is quite large -- it's going to use up a significant amount of the RAM on your ESP8266.
This is probably why it fails at 128bit?
I generated an mpy module from FixedPoint.py and was able to do at least basic stuff in 128-bit.
>>> a = FixedPoint.FXnum(1)
>>> b = FixedPoint.FXnum(3)
>>> print(a/b)
>>> f = FixedPoint.FXfamily(128)
>>> a = FixedPoint.FXnum(1, f)
>>> b = FixedPoint.FXnum(3, f)
>>> print(a/b)
0.333333333333333333333333333333333333332
To do that I checked out the repo at v1.10 (to match the firmware version on my ESP8266), and ran
git checkout v1.10
cd mpy-cross
make -j 16
./mpy-cross -X emit=native -O3 ~/src/github.com/rwpenney/spfpm/FixedPoint.py
This gave me ~/src/github.com/rwpenney/spfpm/FixedPoint.mpy, which I put on the ESP8266 instead of the .py file.
A better approach would be to make a frozen module out of it, so the bytecode will be stored in ROM (Flash) instead. You'll have to build your own firmware, after placing FixedPoint.py in the ports/esp8266/modules directory.
pidou46
Post by pidou46 » Fri May 24, 2019 5:56 pm
Thanks,
I hope it could help ThomasChr
nodemcu V2 (amica)
apollo2mond
Post by apollo2mond » Sun Jun 02, 2019 6:45 pm
hi,, if i follow the described way i get this error:
TypeError: multiple bases have instance lay-out conflict
any further hints regarding?
many thanks
Post by jimmo » Sun Jun 02, 2019 11:43 pm
hi!
Sorry there have been lots of things described in this post - which part were you following?
It's possible though you might have run into to what @pidou46 said "To avoid an error I remove 'TypeError' from line 248 (I will check later thi point)"
glubuluck
Post by glubuluck » Tue Jun 25, 2019 1:17 pm
i just purchased an ESP32-WROOM-32, to try the Roberthh's solution : compile custom FW with double float on ESP32.
But actually, i need help for that...
What do i need ? (sources, compiler..)
How to get it work ?
sorry but my knowledge in micro-controller is just enough to flash regular FW
Thanks a lot
Matthieu
