double precision float on ESP8266
rpr
Re: double precision float on ESP32
Post by rpr » Wed Jun 26, 2019 3:22 am
How does one enable building the firmware for double precision?
Edit to add: This is for an ESP32
kevinkk525
Re: double precision float on ESP8266
Post by kevinkk525 » Wed Jun 26, 2019 5:47 am
I don't know the solution but are you looking for ESP8266 or ESP32? Your title says ESP8266 and your post ESP32..
Kevin Köck
Post by Roberthh » Wed Jun 26, 2019 6:02 am
The place to change is mpconfigport.h in the esp32 directory. Change line:
#define MICROPY_FLOAT_IMPL (MICROPY_FLOAT_IMPL_FLOAT)
into
#define MICROPY_FLOAT_IMPL (MICROPY_FLOAT_IMPL_DOUBLE)
rpr
Post by rpr » Wed Jun 26, 2019 7:11 am
into
Thanks. That worked great.
glubuluck
Post by glubuluck » Wed Jun 26, 2019 7:43 am
Thanks for the hint Roberthh, but i need first to understand how to build the FW.
glubuluck
Re: double precision float on ESP8266 -> ESP32
Post by glubuluck » Wed Jun 26, 2019 9:46 am
hey
maybe i have to start a new thread for this issue but i cannot build esp32 FW.
installed xtensa, esp-idf
matthieu@heronux:~/esp/micropython/ports/esp32$ make V=1
fatal: cannot change to '-s': Aucun fichier ou dossier de ce type
** WARNING **
The git hash of ESP IDF does not match the supported version
The build may complete and the firmware may work but it is not guaranteed
ESP IDF path:       </home/matthieu/esp/esp-idf/>
Current git hash:
Supported git hash: 6b3da6b1882f3b72e904cc90be67e9c4e3f369a9
aucun répertoire fourni pour -C
usage: git [--version] [--help] [-C <path>] [-c <name>=<value>]
           [--exec-path[=<path>]] [--html-path] [--man-path] [--info-path]
           [-p | --paginate | --no-pager] [--no-replace-objects] [--bare]
           [--git-dir=<path>] [--work-tree=<path>] [--namespace=<name>]
           <command> [<args>]
/bin/sh: 1: cannot create /components: Permission denied
GEN build/sdkconfig.h
mkdir -p build/
python3 </home/matthieu/esp/esp-idf/>/tools/kconfig_new/confgen.py \
	--output header build/sdkconfig.h \
	--config boards/sdkconfig \
	--kconfig </home/matthieu/esp/esp-idf/>/Kconfig \
	--env "IDF_TARGET=esp32" \
	--env "IDF_CMAKE=n" \
	--env "COMPONENT_KCONFIGS=" \
	--env "COMPONENT_KCONFIGS_PROJBUILD="
/bin/sh: 1: cannot create /tools/kconfig_new/confgen.py: Directory nonexistent
Makefile:242: recipe for target 'build/sdkconfig.h' failed
make: *** [build/sdkconfig.h] Error 2
i followed the micropython/ports/esp32/readme but... i probably miss something..
Post by Roberthh » Wed Jun 26, 2019 10:58 am
Yes, you have to follow the instructions step by step. Typical errors I use to make:
a) Wrong version checked out (this error is shown in your log):
In the esp-idf directory run the commands:
git checkout 6b3da6b1882f3b72e904cc90be67e9c4e3f369a9
git submodule update --init
b) Forgot git submodule init
In the esp-idf directory, issue the command:
c) ESPIDF not set
You have to set the environment variable ESPIDF to the path of the esp-idf directory. That canbe done permanent, or in the call to make. My preference is a GNUmakefile in the esp32 port directory. My example:
ESPIDF = $(HOME)/Downloads/esp-idf
# SDKCONFIG = boards/sdkconfig.spiram
$(info SDKCONFIG = $(SDKCONFIG))
ESPTOOL=esptool.py
MPY_CROSS_FLAGS = -march=xtensa
include Makefile
Depending on whether you device has SPIRAM, I use one of the two settings for SDKCONFIG.
glubuluck
Post by glubuluck » Fri Jun 28, 2019 7:24 pm
Hey,
so i restarted the building from beginning, following this :
http://www.microdev.it/wp/en/2018/08/08 ... for-esp32/
the build went on but stopped on an Error 1 :
  File "/home/matthieu/esp32/esp-idf/tools/ldgen/ldgen.py", line 22, in <module>
    from fragments import FragmentFileModel
  File "/home/matthieu/esp32/esp-idf/tools/ldgen/fragments.py", line 20, in <module>
    from sdkconfig import SDKConfig
  File "/home/matthieu/esp32/esp-idf/tools/ldgen/sdkconfig.py", line 18, in <module>
    from pyparsing import Word, printables, Combine, Literal, hexnums, quotedString, Optional, nums, removeQuotes, oneOf, Group, infixNotation, opAssoc
ModuleNotFoundError: No module named 'pyparsing'
Makefile:805: recipe for target 'build/esp32.project.ld' failed
make: *** [build/esp32.project.ld] Error 1
any hint to fix it ?
rpr
Post by rpr » Fri Jun 28, 2019 7:51 pm
See the ports/esp32 help page (README.md)
Try the following.
make PYTHON=python2
glubuluck
Post by glubuluck » Fri Jun 28, 2019 9:09 pm
it worked :)
and i'm with 64bit float :P
>>> 10/3
3.333333333333333
>>> 2*math.acos(0)
3.141592653589793
thanks a lot !
Matthieu
