Cannot overload float()
ProudPagan
Post by ProudPagan » Wed May 22, 2019 2:49 am
I am redefining int() and float() for my number-like class (simplified floatoverload class below), but I get a TypeError
when trying to use float(). I am returning a floating point number from __float__ ( ).
int( ) works fine.
Any pointers on what might would be much appreciated. I am using:
MicroPython v1.10-278-g673e154df-dirty on 2019-04-16; win32 version
EDIT: This code works with CPython (tried using 3.6.8)
class floatoverload (object):
	def __init__ (self):
		pass
	def __float__ (self):
		return 99.9
	def __int__ (self):
		return 999
Output:
>>> from floatoverload import floatoverload
>>> int(floatoverload())
999
>>> float(floatoverload())
TypeError: can't convert floatoverload to float
Thanks!
Re: Cannot overload float()
Post by jimmo » Wed May 22, 2019 2:58 am
Unfortunately__float__ is not implemented in MicroPython. If you're interested in the implementation of __int__ search for MP_UNARY_OP_INT in the repo.
Post by pythoncoder » Wed May 22, 2019 8:28 am
In general subclassing built-in types is not supported by MicroPython. See this doc. A solution which works in some cases is to use composition and to simulate inheritance.
