utime.ticks_diff() between pycom and upython
Frida
Post by Frida » Thu May 23, 2019 6:13 pm
In upython, utime.ticks_diff (new, old) gives positive results.
In pycom, utime.ticks_diff (old, new) gives positive results.
Old and new have been switched, I wonder why, there is no
change in the underlying code. It must be somewhere,
between the call and the underlying code.
ps. I prefer the pycom way.
time.time()
start = time.ticks_ms()
while 1:
	#if time.ticks_diff(time.ticks_ms(), start) > 10000: # esp32 pico upython
	if time.ticks_diff(start, time.ticks_ms()) > 10000: # pycom wipy
		break
time.time()
deadline = time.ticks_add(time.ticks_ms(), 100)
#while time.ticks_diff(deadline, time.ticks_ms()) > 0:	# esp32 pico upython
#	print(time.ticks_diff(deadline, time.ticks_ms()))	# esp32 pico upython
while time.ticks_diff(time.ticks_ms(), deadline) > 0:	# pycom wipy
	print(time.ticks_diff(time.ticks_ms(), deadline))	# pycom wipy
Yes Frida is my watchdog!
Christian Walther
Re: utime.ticks_diff() between pycom and upython
Post by Christian Walther » Thu May 23, 2019 7:08 pm
It was changed at some point after a lengthy discussion: https://github.com/micropython/micropython/issues/2217
Post by Roberthh » Fri May 24, 2019 5:44 am
Obviously there is a difference in the underlying code, and yes, this change by Pycom was definitely not necessary, and they may switch back. Besides that, you can make you code for that, by introducing a factor:
diff = ticks_diff(old, new) * ticks_diff(1, 2)
That will give you the same result on both systems. If you pre-calculate the factor, you'll save the second call.
Post by dhylands » Fri May 24, 2019 1:41 pm
Presumably, the second call should be ticks_diff(1, 2)
Post by Roberthh » Fri May 24, 2019 1:50 pm
Sure
