object-oriented programming
mschulz
Re: object-oriented programming
Post by mschulz » Mon Apr 27, 2015 7:56 am
With an other pins it works,
But the switch callback
# USR Schalter
print ('INIT des Schalters')
switch = pyb.Switch()
def switchcallback():
    print('INFO-Switch: Switch Callback aufgerufen!')
switch.callback(lambda :switchcallback())
only starts one time.
Which is the best solution to stop the scheduler with a push button (the USR or an hardware interrupt (a button I can braze on other pins)
(and restart it)
Post by dhylands » Thu Apr 19, 2018 4:49 pm
You can pass switchcallback directly to the callback function.
What you coded:
is equivalent to:
x = switchcallback()
switch.callback(lamba: x)
You can code it like this:
switch.callback(switchcallback)
Note that there are no parenthesis so it passes in the address of the function whereas with the parenthesis it calls the function.
