Trouble reading analog Input from Arduino Shield using XBee3 Module
Posted: Sun Jun 09, 2019 1:06 pm
Hello Forum,
i'm using Micropython installed on my XBee3 ZigBee module (https://www.sparkfun.com/products/15129).
The Module is plugged into an Arduino Uno Shield and i want to put the output Pins of an analog Heart-Beat-sensor into that shield and read the incoming data from the XBee3 with micropython.
Check out the link to see the Setup: https://imgur.com/a/r3bqDjW
So far, i only found documentation about how to access the Pins directly attached to the module (https://www.digi.com/resources/document ... /90001539/).
But how can i access the Pins on the Arduino Shield?
Any hint of how i could achieve that is highly appreciated!
