Any OSError Codes as of now?
cahe
Post by cahe » Sun Jun 23, 2019 12:12 pm
Hi team, is there any OSError code list with translation what each code implies? As that I feel the codes are not completed yet.
Regards,
Cahe https://dltutuapp.com/tutuapp-download/ https://showbox.run/ https://kodi.software/
rhubarbdog
Re: Any OSError Codes as of now?
Post by rhubarbdog » Mon Jun 24, 2019 3:31 pm
They are just text versions of the constants defined in file errno.h. micropython sticks to these eg ENODEV to remain lean.
If you need a translator to convert these to english you need to write a C program
Post by jimmo » Tue Jun 25, 2019 12:28 am
Using regular CPython:
>>> import os
>>> os.strerror(27)
'File too large'
These aren't included in MicroPython because it's just a lot of space to take up.
vicyclefive
Post by vicyclefive » Mon Jan 18, 2021 6:00 am
I want to handle specific OSError codes like this:
os.scandir()
except OSPermissionError as error:
# Only catch errno.EACCES, errno.EPERM
handle_permission_error()
except OSFileNotFoundError as error:
# Only catch errno.ENOENT
handle_FileNotFoundError_error()
Can this be done in python? shareit get-vidmateapk.com
Post by jimmo » Tue Jan 19, 2021 2:48 am
I think you need to do something like:
EFOO = const(1)
  os.scandir()
except OSError as error:
  if error.args[0] == EFOO:
    # handle foo
  elif ...
Chai3
Post by Chai3 » Sat Feb 13, 2021 9:29 am
os.scandir()
doesn't throw these types of exceptions. It raises the OSError exception. It does, however, allow you to determine the type of error that occurred.
There are a large number of possible errors that could be part of the
OSError
. You can use these to raise your own custom exceptions and then handle them further up the stack.
class OSPermissionError(Exception):
    pass
class OSFileNotFoundError(Exception):
    pass
    os.scandir()
    # Not found
    if error.errno == errno.ENOENT:
        raise OSFileNotFoundError()
    # Permissions Error
    elif error.errno in [errno.EPERM, errno.EACCES]:
        raise OSPermissionError()
        raise
Best regard's
https://gbapps.net
