Wemos with a serial/USB chip based on CH304G - using for micropython
apollodriver
Post by apollodriver » Wed Aug 07, 2019 3:41 pm
hello dear experts,
this tutorial here - ( regarding the rc car that runs with micropython ) notes the following
Step 4: MicroPython Installation
cf: https://www.instructables.com/id/MicroP ... SP-8266EX/
First, Wemos has a serial/USB chip based on CH304G. This is the same chip found in cheap Arduino-clones and you must install a proper driver for Mac or PC. Follow the instructions on this site to install the driver. Connect Wemos to your computer and confirm that your computer could detect Wemos. On Mac, run the following command and you will see a device called /dev/tty.wchusbserial640.
well - is the chip that is mentioned - Wemos has a serial/USB chip based on CH304G - is it on the WEMOS Board or should i add them on a
breakout-board!?
love to hear from you,
regards Apollo
WPGear.org is a compendium of useful developer tools for working with WordPress.
Re: Wemos with a serial/USB chip based on CH304G - using for micropython
Post by Roberthh » Wed Aug 07, 2019 4:06 pm
The CH340G chip us on the Wemis boards which thus have an USB socket & intetface.
apollodriver
Post by apollodriver » Thu Aug 08, 2019 6:25 am
hello dear Roberthh,
many many thanks for all you did _ i am very very glad about your help.
greetings
