Wemos with a serial/USB chip based on CH304G - using for micropython
Posted: Wed Aug 07, 2019 3:41 pm
hello dear experts,
this tutorial here - ( regarding the rc car that runs with micropython ) notes the following
Step 4: MicroPython Installation
cf: https://www.instructables.com/id/MicroP ... SP-8266EX/
breakout-board!?
love to hear from you,
regards Apollo
well - is the chip that is mentioned - Wemos has a serial/USB chip based on CH304G - is it on the WEMOS Board or should i add them on aFirst, Wemos has a serial/USB chip based on CH304G. This is the same chip found in cheap Arduino-clones and you must install a proper driver for Mac or PC. Follow the instructions on this site to install the driver. Connect Wemos to your computer and confirm that your computer could detect Wemos. On Mac, run the following command and you will see a device called /dev/tty.wchusbserial640.
breakout-board!?
regards Apollo
