socket.getaddrinfo takes too long to respond
akushva
Post by akushva » Mon Aug 12, 2019 6:08 am
I'm trying to use socket library in my application on ESP32. I'm trying to connect to a device via it's IP address using the command below-
sock.connect(socket.getaddrinfo(device_IP, device_port)[0][-1])
I noticed that it takes around 19-20 seconds whenever there is a failure in connection or I put wrong IP address, after which it responds with this error:
[Errno 113] EHOSTUNREACH
The timeout argument in socket library doesn't help it and I'm am unable to connect to a device when I configure the socket to be a non-blocking socket.
Is there a way so that I can reduce this waiting time down to 2-4 seconds.
Thanks.
Re: socket.getaddrinfo takes too long to respond
Post by pythoncoder » Tue Aug 13, 2019 8:19 am
Perhaps I'm missing something but I can't replicate this on the ESP32 reference board. The following code runs "instantly" whether or not a connection to my WiFi is running. The device does not exist on my network and a ping produces "Destination Host Unreachable".
>>> usocket.getaddrinfo('192.168.0.55', 1234)[0][-1]
You could create the tuple directly, but this is a hack and your approach is the correct one.
If you're doing a DNS lookup by name getaddrinfo will block for a period depending on the response time of your DNS server. This is a known limitation. The need for a nonblocking solution has been discussed but as far as I know has not been written.
